The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 18-04-2007   #1
Trader Rating: (0)
rcarter has donated!
Front Shocks on Mk1 1999
I have a leaky shock, just started, do I need a spring compressor to change them. Also are the sprind part of the shock?
rcarter is offline
Old 18-04-2007   #2
just can't get enough
toad101's Avatar
Trader Rating: (0)
toad101 has donated! United Kingdom
Re: Front Shocks on Mk1 1999
yes you'll need a spring compressor, no the springs aren't paret of the shocks, you should change shock is pairs ie;front pair
toad101 is offline
Old 18-04-2007   #3
Trader Rating: (0)
Do you intend to take off the shocks yourself?
samsonite is offline
Old 18-04-2007   #4
Trader Rating: (0)
Yes I will take these off myself, and replace as a pair, any tips, looks ok to do.
rcarter is offline
Old 18-04-2007   #5
Trader Rating: (0)
you need to take off the wheel,s disconnect the wishbone/hub from the bottom of the shock. undo the bolts at the top of the shock tower (engine bay) and your shock is off.... then clamp the springs, remove them and fit the new ones as you removed these!
Old 19-04-2007   #6
Trader Rating: (0)
I took my shocks with the springs on to my local garage and they took the old springs off and put my new springs on for free - i tried with the spring compressors but they kept slipping and was a real pain, i even managed to bend a spring compressor
teulk is offline
vB code is On
How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto 543 06-06-2008 16:15
