Technical warning light on fiat grande punto mjd
Sauraabh2177
i have the following warning light since today evening (image attached) light.jpg .
not able to find anything on the manual on it and neither on the forum.
any help will be appreciated.
The red one is brake warning light (assumed you knew that, otherwise get your braked checked out).
The amber spanner is the service due indicator light.
Should be reset by dealer at service time.
Can also be reset by MultiECUScan (I think) if you have it.
Maybe also with a sequence of operations using ignition key and trip reset button... not tried it myself, but there are numerous how-to videos online if you search for "fiat punto spanner reset" or similar.
yes thanks for pointing out.
i got it serviced at a local garage .
and i did try the steps shown for getting rid of this light but they do not help in my case.:mad:
