Technical Twinair - Air Filter replacement (UFI guide)
A dead fly, a mucky pollen filter and some carbines spark plugs
Oh and some skinny pads
I took plenty of pictures but most are covered already... Plugs have plenty of info in the 500 section. Forgot to check the electrode gap before fitting the plugs but don't know what it should be.
Was caught out on the calliper carriers as are fixed by star head bolts. I used 16epl socket but had to nip out mid job to go get a set.
Also 7mm Allan key, 30 torx and a 9mm ring spanner for bleed screw. All odd sizes IMO.
Got there in the end but as ever the calliper carriers needed a good clean where the pads should slide. Disks were hardly worn on the inner surface so suggest callipers not sliding over the carriers so well.
Oh you've got a green'un...
Almost... My Mrs has a green'en :) I'm still in the Panda Sporting.
I really don't know about the spec as I didn't do any research.
It's a 5 door, very green (with black roof) and supposed to use very little Petrol.
Were they all green at first? they seemed to drop the TA engine after about a year :confused: wonder if that was just the cold UK or global?
