Hi any help or advice much appreciated.
Have a 2008 P unto grande diesel 1.3 dynamic.
125k on the clock, had some work done.
i think the clutch is maybe had it days.
its Hard to get into gear, as i have to push clutch pedal all way to foot-well metal.. and reverse is night mare sounds like teeth running across Cogs but just not engaging until after a couple tugs i gets in reverse gear, with that familiar crunch as it enters reverse gear.
So i assuming the clutch is a self adjusting as i don't see a way to tension up clutch cables.
If i was to have to replace it was cost would you guestimate ?.
