| | Thread Tools | Search this Thread |
| is it a certain brake fluid i must buy?.. its a Punto Sporting (02) and where can i find where to put it.. i am a Fiat rookie.. i just bort this car last week and loving it!
| oh me gums! | Re: My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will it will be dot 4 or better. dot 4 is a specification not a brand. you can go higher as in dot 5.1 but 4 is fine. what are you doing that you need fluid? is it losing fluid? | ||
| | #3 | ||
| Re: My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will it must used up as the Warning light keeps flashing up on the dash, misc times and after i brake.. also i cant find where to put it??...
| | #4 | ||
| oh me gums! | Re: My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will have you checked the fluid levels? could be a wire fault for example also may be a leaking master cylinder so topping up is only a temp fix. the resevoir is on the engine bulkhead | ||
| | #5 | ||
| Re: My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will Your brake pads are low, if you change the pads it will raise the level in the brake res back up.
| | #6 | ||
| | FiatStiloJTD | Punto | 543 | 06-06-2008 17:15 |
| | christophe | Punto | 5 | 31-10-2005 16:11 |
