| Punto elx fan switch!!! can anyone tell me where my fan switch is under my bonnett, my fan wont work!!!
| Re: Punto elx fan switch!!! Have you got a mk1 or mk2?
| | #3 | ||
| Re: Punto elx fan switch!!! i dont know lol!!
| | #5 | ||
| Re: Punto elx fan switch!!! L reg 1994
| | #6 | ||
| Re: Punto elx fan switch!!! MK1, did you check the fuse? if not blown, start at the fan and work your way back with an electrical tester, and try powering the fan from the battery to check it works good luck Ant!
| | #7 | ||
| Re: Punto elx fan switch!!! i have connected fan to battery and it works??
| | #9 | ||
| | #10 | ||
| Re: Punto elx fan switch!!! thanks very much for your help will try this
| | #11 | ||
| Re: Punto elx fan switch!!! if you are going to remove fanswitch,you will first have to drain coolant from the rad ,the once u remove fan switch it would be worth immersing if in hot boiling water to see if it cuts in(switches on) and for this you could attach a 12 volt supply to the switch terminalstogether with either a test lamp on voltmeter .
| | #12 | ||
| Misseys Stalker! | Re: Punto elx fan switch!!! the fan switch is located at the bottom of the radiator on the same side as the radiator filler cap,. you'll see a cable with a plug connector on it, unplug this and bridge the two wires in it with a piece of wire. the fan should now come on, if i does then you know that the rest of the circuit is fine and the fan switch is the problem, if it doesnt then you can check the fuse as described in one of the above posts,.,.
| | FiatStiloJTD | Punto | 543 | 06-06-2008 17:15 |
