| Solution to Punto 75 mk1 Engine Problem I have a Punto 75 SX M reg (95)and had the following problems 1) At idle the revs where not stable 2) Could not hold revs at certain rpm 3) Excessice CO emissions 4) A hesitation at 3000rpm and then a sudden surge of power like turbo Problems 2&3 where found at the recent MOT test,and the tester suggested that was the throttle position sensor, becasue the lambda sensor was OK (the limits 0.98 to 1.03 mine was 1.01) A friend suggested this site a some of you suggested that could possible the temperature sensor. I was confused and did not want to pay for fault read test (from 40 to 60 £ per hour) I decided to call a friend from my origin country specialising in Alfa Romeos and FIAT's. I told him the symptoms and he categorically said it was the lambda sensor, I replied that was inside the limits and yet insisted that was lambda sensor. He even decided to pay for the sensor if was not the problem. His own words were "if the revs are not steady and fail in CO emissins and not in HC emmissions then it is lambda sensor... a lot of FIATS have that problem. The problem is caused that the sensor is 'slow' (picking the signal right but not responding accordingly)" I bought the lambda sensor (original £65, non-original £55, I opted for the orignal) and changed it. The changing is very easy and straightforward, a 22 spanner a screwdriver is all you need. The problem was solved and passed the MOT. So if anyone has the same symptoms then it is the lambda sensor even if it reads OK I decided to share my story in the forum in order to help other Punto owners but I don not imply that this is the solution to all cases I hope that I gave some help
| __________ | Hi welcome to the forum:) Thanks for sharing that with us. ---------------------------------------------------------------------------------- Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
| | #3 | ||
| Join Date: Oct 2003 Location: buxton the land that time forgot
Thanks: 1 Trader Rating: (0) | Wow i got exact same problem recently iwent for an mot and the people were unable to hold my car at 2500 revs they tried for several minutes i was getting annoyed as i thought they were just idiots lol they passed me anyway i wasnt complaining lol. also my revs bounce at idle sometimes, and i get that powerloss atabout 3000rpm some times it stays sometimes it goes and i get sudden bursrt of power. my car is a 2001 sporting but would seem like the lambda sensor for deffinate from what you have said and from what others had said in a previous post i made. cheers for the post 2001 Punto sporting in sprint blue with matching Mr Bump air freshner all together now mmmmmmm
| | #4 | ||
| Re: THE LAMBDA SENSOR I Had All The Usual Problems Of Juddering Starts, Dodgy Tick Over, Holding Back & The Sudden Surge Of Turbo Power. Traced It Back To The Lambda Sensor, Situated On The Exhaust Manifold, Between The Engine & The Radiator. Mine Is A Gold Coloured Thing, Looks A Bit Like A Spark Plug. Anyway, To Magically Cure All Your Problems, Simply Locate The Dreaded Thing, Then Trace The Wire Back To The Plug In Socket, & Unplug The Thing !! You Will Find That Your Car Runs Absolutley Beutifully Without It! Ive Been So Happy Since, I Thought I Would Share It With The World.
| | #5 | ||
| Re: Solution to Punto 75 mk1 Engine Problem HI JUST UNPLUG THE LAMBDA SENDOR UNIT IT SHOULD RUN BETTER AND THEN YOU NO IF IT IS THAT
| | ice0018 | Punto | 7 | 06-06-2007 11:14 |
| | shotter | Punto | 17 | 30-12-2006 12:45 |
| | tubi | Punto | 7 | 28-02-2006 13:48 |
| | broadfield | Punto | 4 | 02-11-2003 03:41 |
| | zokipet | Punto | 3 | 22-02-2003 04:37 |
