| Hi folks, I've recently got a Punto mk1 75S 1995. I wasn't expecting much acceleration and top speed but as it is now there must be something wrong (this is a 75 horse power engine ). Acceleration is poor and max. speed is not more than 140-142km/h (about 87 mph) with the engine already at 4000-4200 rpm... The former owner (my brother) told me he's gone about 160-170 km/h (102-103 mph) with it (and he wasn't talking about the year he bought the car, he talked about last year). I last week changed the lambda sensor but unfortunately it hasn't really helped. Sometimes the emissions are quite "smelly" (although the new lambda sensor seems to have helped with it). I was now wondering whether the problem could be the CATALYTIC CONVERTER. Could this actually be the problem? If so, does anyone know any online shop where I could but one? Thanks for your help, /N
| Re: low top speed/acceleration punto 75 mk1 What sort of smell is it? A 75sx off the top of my head does 0-60 (0-100km) in about 12.5 seconds and goes onto a top of about 103 mph. When was it last serviced and what did the service entail? (aka, what did you do?)
__________________ Driving: Alfa Romeo 145 Cloverleaf in ZOE yellow. Also owns: Mk1 punto sporting, Damaged. For sale!! Pm for more info | |||
| | #3 | ||
| Reppin MK5..... | Re: low top speed/acceleration punto 75 mk1 i have the same problem with my mk2 1.2 8v! same top speed as you. mine has a sort of "sweet" smell, if you know what i mean, sort of gas smelling but not quite lol.
| | #4 | ||
| Re: low top speed/acceleration punto 75 mk1 Thanks for your reply Ransoman. It was a strong gasoline-combustion smell but it happened just sometimes (seldom) and it seems to be fixed with the new lambda sensor. I don't really know last time the car was serviced in a garage... I did changed all the filters (air and oil) and the oil last summer (I did it myself). Based on your experience, could it be the catalytic converter the reason for such a lack of power? What else could it be that is causing this problem?
| | #6 | |||||
| | #7 | |||
If i where you i would put a bottle of forte engine flush in (no other brand), and run it for 200 miles, then drain the oil and fill it with ONLY selenia 20k (plus new oil filter), Replace the spark plugs and the HT leads (make sure they are gapped correctly) and a new air filter. Once you have done all that your car will be tip top again. if you do all that yourself (really easy) it should cost you no more than £80. Hope this helps.
__________________ Driving: Alfa Romeo 145 Cloverleaf in ZOE yellow. Also owns: Mk1 punto sporting, Damaged. For sale!! Pm for more info | ||||
| | #8 | ||
| Re: low top speed/acceleration punto 75 mk1 Could it be the water temp sensor? It could always be trying to run on cold start caused by a faulty water temp sensor telling it the engines cold. The problem could be getting masked by the new lambda sensor. Think how a carb engine loses power when the choke is out any the engines warm.
| How many Puntos are there on the Forum? - The Thread | FiatStiloJTD | Punto | 543 | 06-06-2008 17:15 |
