The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto > Punto > Technical
Old 12-07-2006   #1
Werner's Avatar
Trader Rating: (0)
Steering wheel
Hi, I have not done much car modifications and so I am not too sure on everything.
I want to replace my steering wheel as it is very old with wear and tear.
Iv got a Punto Mk1 (97 model), just want to know how exactly do i remove the steering wheel?
I have found 3 screws on the under side which i removed, but that just removed the underside cover of the dash.
The new steering wheel is a universal fit, have also seen it described as a momo type fit. Can this type of steering wheel fit on directly, or would I need to get a boss kit or something?
Thanks for any help
Werner is offline
Old 14-07-2006   #2
Trader Rating: (0)
Re: Steering wheel
hi tere,to remove the steering wheel,1st put your steering wheel in the straight ahead position.remove the horn by undoing 3 allen bolts behind the steering wheel,pull horn off gently and undo the wire.then undo big nut in centre of wheel,24 mm I think. get some one to hold the s/wheel while you undo it with a big bar,9" to 12" should do, you could mark the position of the nut before you slacken it, so you do not under or over thighten the s/wheel if you put the same one back,once nut is of,make a fist with your hands and bang the s/wheel as hard as you can till the s/wheel comes loose.best to hit it at quarter to nine and quarter past three position as on a clock face,that sould get you s/wheel off,you will have to sort fitting the new one out your self,hope this helps.........M
multipete is offline
Old 17-07-2006   #3
Werner's Avatar
Trader Rating: (0)
Re: Steering wheel
Thank you very much, i will try that and hopefully it wil work.
Werner is offline
vB code is On
For Sale: Fiat Bravo/a Leather Steering Wheel with Airbag (FIAT Bravo / Brava Parts) JoskeJTD For Sale / Wanted 0 06-06-2006 09:47
New OMP Steering Wheel...but no beep? sikersh Cinq/Sei > Technical 7 13-05-2006 22:42
sports steering wheel insteed of original steering wheel vdhi Punto > Technical 7 18-04-2006 12:12
Anyone fitted an aftermarket steering wheel?? My Little Panda Panda (Classic) 14 04-04-2006 17:16
MAREA steering wheel remote 2 SONY adapter finished .... Struja Marea 3 29-04-2005 09:03
