| Checking spark plugs, leads and coil packs Hi all, Engines running a bit lumpy on my punto 1.2 60s since i replaced the head gasket, and i recall one of the spark plugs being black when all the others were greyish, what's the best way to check the plugs, leads and coil packs to see if there's any faults anywhere? I read on another thread about unplugging each lead in turn while the engine is running, i'm guessing it's the coil pack end of the lead that i should pull out? Whilst i'm posting, the car's been on the drive for about 8-9 months now so is there anything in particular i should check before i try and get it an MOT? I've checked over the main points using the Haynes manual, fitted new brake discs and pads as the last ones had binded and corroded, and stuck some redex in the petrol tank, just wondering if there's anything else? Thanks in advance! James
| Grumpy Forum Moderator | Re: Checking spark plugs, leads and coil packs I'd change plugs/leads anyway as a matter of course if its been sitting that long.
__________________ IF YOU'RE HERE TO MOAN OR SLAG FIATS - DONT BOTHER! | ||
| | tinpan | Punto | 1 | 21-06-2006 17:02 |
| no spark | leafblower | Spider | 30 | 07-02-2006 03:06 |
| Fiat Punto Gt Coil Pack & Ht Leads | punto gt old man | Auction Watch | 1 | 15-01-2006 01:16 |
| No spark! 1989 Tipo 1.4 DGT | LezH | Tipo | 6 | 01-05-2005 10:12 |
| | red_cinqo | Cinquecento / Seicento | 12 | 12-10-2004 17:19 |
