| __________ | just put a 75 gearbox into daryls car a 60. the 75 linkage bar looked diffrent so i fitted that on, now i have no reverse where reverse is supposed to be is another forward gear wtf going on there then
__________________ Binki | ||
| Simplify & Add Lightness | Re: extra forward gear no reverse Does that make it a 7 speed gearbox? If so, GAME ON!
__________________ Mk2 Punto 1.9JTD - GSR/ChippedUK tuned - 118bhp/187lb/ft Want a set of Sporting Alloys? www.SpiritoDiPunto.com - For technical talk and all things Punto! ![]() | ||
| | #3 | ||
| Scandinavian Passion.... | Re: extra forward gear no reverse You haven't got 5 reverse gears & 1 forward? Or if you've got 6 forward gears you'll have one 'duplicated' ratio.
| | #4 | ||
| ***** Friendly | Re: extra forward gear no reverse didnt they make a 6 speed Punto at some point maybe you got one of them
| | #5 | ||
| Bit like a American Stock car, they don't need a reverse How you going to fix it Dave??
__________________ Fiat Seicento Sporting, Dark Met Grey, K&N air filter, Power flow exhaust, BBR Starchip, Pi -35mm lowering springs, 14” Kosei RG silvers, Pug 106 skirts, NeoDesign Rally spoiler,(Currently on the run?) Honda CBR 1100 Fire Storm Motorbike wing mirrors, Smoked Front Indicators, De-badged rear, OMP bucket seats with sub frames & harnesses | |||
| | #6 | |||
__________________ Mk2 Punto 1.9JTD - GSR/ChippedUK tuned - 118bhp/187lb/ft Want a set of Sporting Alloys? www.SpiritoDiPunto.com - For technical talk and all things Punto! ![]() | |||
| | #7 | ||
| oh me gums! | Re: extra forward gear no reverse hmm what sort of gear is it?eg a low 1st like gear or a higher 4th type gear? wondering if its snicking into a forward gear due to the different bar set up | ||
| | #8 | ||
| __________ | Re: extra forward gear no reverse its defently a 5 speed box and was working fine in the donor car, i couldnt fit it with the old linkage, as when i did gearstick was stuck right over on the drivers side ![]() i dont know what gear is where reverse is supposed to be,as i havent took it for a drive
| | #9 | |||||
| | #10 | ||
| Burninator of threads! | Re: extra forward gear no reverse it could be a six speed box, but AFAIK reverse is still in the same place, just a bit closer to driver as 6th is where Rev normally is. I've got a 6speeder sat here, waiting for my current clutch to die (it just keeps going!!! mk1 clutchs so splash on mk2 clutchs maybe it had a 6speed fitted to it at some time or another, in which case you DO need the linkages, as they are slightly different. sure you didn't fit one or another linkage upside down, or on the wrong side of a bearing.
__________________ ![]() Volvo for Life | ||
| | #12 | ||
| Burninator of threads! | Re: extra forward gear no reverse so maybe you've mounted the linkages wrong, or you have made up some weird combo of the old and newer linkages that doesn't work
| | #13 | |||
| Mr Pedantic | Re: extra forward gear no reverse
![]() H | |||
| | mansellkarl | Punto | 11 | 03-08-2005 21:42 |
| | Zimon | Cinquecento / Seicento | 15 | 03-07-2005 13:55 |
| | GhostWKD | Cinquecento / Seicento | 17 | 22-09-2004 07:06 |
| | HornetUK | Stilo | 3 | 01-09-2004 20:02 |
| | Pete600 | Cinquecento / Seicento | 10 | 08-05-2003 05:33 |
