| Centre Bore for Alloys? Do you need to look for alloys with the exact Centre Bore dimensions as your car? Or (I hope) is there a bit of play or a way around the problem when fitting aftermarket alloys in replacement for the standard alloys? I wanna know for instance can you fit alloys with 50mm C/Bore onto a car with a 60mm C/Bore easily? I know to use wobbly bolts to get around PCD i.e use wobbly bolts to fit 4x100 to your 4x98 wheel fitments. But C/Bore's?????? ![]()
| | #2 | |||
| Re: Centre Bore for Alloys? wouldnt spigott rings sort that problem out?
__________________ For Sale: BMC CDA, see classifieds!
< Team Anthracite > | ||||
| | #3 | ||
| Re: Centre Bore for Alloys? I don't know? What are spigott rings and how do they work? Hopfully they do as I have my heart set on a set of alloys but they are 7mm smaller on C/Bore that my Punto and I would really like to get them ![]()
| | #5 | ||
| Re: Centre Bore for Alloys? Most aftermarket alloys dont have a centre bore as such, they use spigot rings to change the centre bore to that of the vehicle theyre fitting. What alloys are you after?
| | #6 | ||
| Re: Centre Bore for Alloys? The are Inovit "Back Spin Graphite diamond Cut" alloys Sorry no photo to hand of them.
| | #7 | ||
| __________ | Re: Centre Bore for Alloys?
__________________ Binki | ||
| | #8 | ||
| Re: Centre Bore for Alloys? Nope............. http://www.inovit.com/spin.htm But thanks for the link Dave. Helped me find the lonk to the ones I like
| | #10 | ||
| Re: Centre Bore for Alloys? comes in 4 stud too!
| Alloy wheel hub adaptors to allow diff. PCD centre bore! | J333EVO | Cinq/Sei > Technical | 0 | 13-02-2006 23:14 |
| Centre console and door pods... great... not | T.E.D. Jordan | Punto > Styling | 7 | 25-12-2005 00:23 |
| As its asked often here is PCD, off-set & centre bore chart. | J333EVO | Cinq/Sei > Technical | 10 | 13-10-2005 14:58 |
| bore size | Firewarrior | Cinq/Sei > Technical | 5 | 27-09-2005 19:40 |
| Multipla - can't remove centre rear seat | bikeman | Multipla | 1 | 13-08-2005 16:39 |
