| Please can someone help as this noise is doing my nut in i have a Punto 03 with a sreeching sqweaking creeking noise from passenger side at rear when i go over a slightly bumpy road. Does anyone have a clue what it is & how i may be able to stop it. Thanks..
| Join Date: Oct 2003 Location: buxton the land that time forgot
Thanks: 1 Trader Rating: (0) | Re: Punto mk2 noise coming from rear passenger side hmmm think i remember a thread before abnout this and its somthing to do with a handbrake cable rubbing on sumthing. other things you can check are make sure spare is not looose. make sure rear seat is fully locked back. also if you have the fiat sub make sure its bolted down well.
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm | ||
| | #3 | ||
| The Older Modder | Re: Punto mk2 noise coming from rear passenger side I have it in the same place mine has been caused by lowering the car and the lip of the bumper touching the wheel as I go over bumps,Steve
__________________ Never drive faster than your Guardian Angel can fly!! You can only be young ONCE, but you can be IMMATURE for EVER!! | ||
| | #4 | ||
| Re: Punto mk2 noise coming from rear passenger side Just sorted it ( i hope ) i bent down on the passenger side towards the back of the car and seen what i thought was the hand break cable, i moved it and it made the noise ( i wasnt sure if it was the noise coz it wasnt as loud ) so i greased it up & went round the block a few times, no noise at all. Hopefully that was it. Happy dayz
| | #5 | ||
| blessed are the apostates | Re: Punto mk2 noise coming from rear passenger side i remember a few years ago i was trying to find a rattle my escort had around the N/S/R wheel. after weeks of searching i found a 10mm nut that was sitting inbetween the inner and outer skins of the rear wing. i only found it by poking a magnet rod down into the bodywork. that nut had rattled me silly for 20k, soooo annoying | ||
| | #6 | |||
yep thats the one i was thinking off hav seen several posts with that problem
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm | |||
| | #7 | ||
| Ever since I bought my 52 plate Punto in jan 07 I have had a terrible squeak coming from the back of the car on the passenger side. It used to be intermittent, getting better in the rain, but recently it has become much worse.. CONSTANT infact .. to the point where it was putting me in a bad mood everytime I drove it.. I thought I was going to go crazy. All things went through my mind .. suspension.. dry bush maybe ? So yesturday after returning from work I climbed under the car and had a poke about. I moved the handbrake cable and to my surprise I heard the same noise but VERY VERY quietly .. so quiet I thought "It can't be that"... off I went to the shed and got some silicone based lubricant and covered the two brackets by the wheel holding the cable. With fingers crossed I went for a 10 mile drive and not one squeak! Just bought some copper grease and some cable ties to make sure it doesn't come back ! Woooooooooooooooooooooooooooooooooo!!! Im sane again !!
| Die Hard!!! | The Negotiator | Leisure Lounge | 27 | 24-04-2006 22:20 |
| | Body Stylist | Punto | 30 | 09-04-2005 17:02 |
| | ewi080 | Stilo | 14 | 22-02-2005 11:40 |
| | cholmes0305 | Uno | 3 | 03-04-2004 08:10 |
| speakers in rear of punto mk2 | fiat_cinq_driver | I.C.E | 4 | 02-11-2003 20:58 |
