The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto > Punto > Technical
Old 10-11-2003   #1
Principality Retained :)
arseofbox's Avatar
Trader Rating: (3)
arseofbox has donated! United Kingdom
Fiat Punto ECU Wiring Diagrams
I wonder if any of you nice people in this part of the forum could do me a massive favour...
Im looking to put a Punto 1242 into my 899 Cinq, and I understand that I must change the ECU to do this.
I know the Punto 1.1 94-96 has the same model of ECU but a different map to the Cinq.
The 1.2 Punto has a similar ECU (16F as opposed to 6F), and the Cinq changed from the 6F to the 16F in 1995.
Im just wondering if someone with one of the following cars could scan in the circuit diagram for their car's ECU from a haynes manual??
Cars:
Punto 1.1 95 on
Punto 1.2 all models
Arse
Ill think of something witty....just wait and see............wait I might not.
arseofbox is offline
Old 11-11-2003   #2
Trader Rating: (0)
Easier all round if you just use the ECU that came with the 1242 engine you are using. At least you know it'll work.
www.puntoforum.co.uk
Evil-Punto AKA Evilution.
Evil-Punto is offline
Old 11-11-2003   #3
Trader Rating: (0)
Yes you are right the mapping is different but it will still work. Ecu IAW 6F Does not have key code IAW 16F Does have code system so you would also need these keys
FiatExpert is offline
Old 11-11-2003   #4
arseofbox's Avatar
Trader Rating: (3)
Yes, I appreciate both of those things- I need a 1242 ECU Wiring Diagram to find out how much wiring I would need to alter\ change.
Also- some people on the Cinq section have no immobilizer on a Sporting (16F ECU), and the Punto 1242 between 1994 and 1996 uses a 6F ECU so a direct swap I think??
'Ang On- so I could even use my 899cc (6F) ECU???? That would make life one hell of a lot easier.....
Arse
Old 12-11-2003   #5
Trader Rating: (0)
If a 16F ecu doesn't have keycode then that because usaully its be decoded and the code ecu ripped off, thus not recoding the fuel ecu and its always virgin.
Old 12-11-2003   #6
arseofbox's Avatar
Trader Rating: (3)
But is there anything stopping me from using my 899cc mapped 6F ECU for the conversion?? That'd make life a lot easier as it all wired in as it is....
Arse
Old 13-11-2003   #7
Trader Rating: (0)
I,ve had had one 1108 spi running with and 899 ecu with out any major problems but its idle speed was a bit erratic
Old 14-11-2003   #8
arseofbox's Avatar
Trader Rating: (3)
So I could probably do it...but it would need a bit of fooling to make it idle correctly??
Arse
Old 20-03-2006   #9
Trader Rating: (0)
Re: Fiat Punto ECU Wiring Diagrams
i have a 1.2 punto ECU 4 sale if ur interested
wardy1985 is offline
vB code is On
MODELS FIAT SHOULD MAKE! jetweed Lets Talk FIAT 61 30-08-2004 20:38
ORIGINAL FIAT CD Manuals - Punto mk2 alfanige Punto > Technical 0 02-04-2004 02:49
Fiat Punto super 1600: Champion!!! roby76it Lets Talk FIAT 2 23-10-2003 19:50
Fiat Bravo (moved thread) sonia cachia Bravo / Brava 7 20-10-2003 03:30
Fiat recalls - Punto [1] roby76it Lets Talk FIAT 0 14-04-2003 01:50
