The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto > Punto > Technical
Old 16-09-2003   #1
Trader Rating: (0)
Goaning noise from new timing belt
Hey all...
First time post here - forgive me if this is a stupid question. A couple of months ago I got a main Fiat dealer to change the timing belt on my Mk I 1.1l 55SX (53k miles). Ever since, the gubbins around the timing belt area have made a funny groaning/whining noise when going between about 1k - 2k revs when the engine is warm.
Someone mentioned that the new belt might be too tight, so I took it back to the garage and they say that the timing belt cover is causing the noise. Now it is a little loose (you can wobble it), but I really don't think it's the culprit. It's going back next week for a new cover anyway.
Has anyone had any similar experiences? Any other thoughts?
Ta!
Ben
bjw105 is offline
Old 16-09-2003   #2
__________
dave's Avatar
Trader Rating: (9)
dave has donated! Saint Kitts and Nevis
If the new cover don't sort it, it might be timing belt tensioner bearing.
dave is offline
Old 17-09-2003   #3
Trader Rating: (0)
Difficult to be sure without hearing it, but an overtight belt does make some funny noises...
John H is offline
Old 18-09-2003   #4
Trader Rating: (0)
Thanks for that...
The tensioner was replaced at the same time as the belt - so I'd be tempted to rule that one out. I'll wait and see what effects the new cover will have.
Ben
bjw105 is offline
Old 23-09-2003   #5
Trader Rating: (0)
As suspected, replacing the timing belt cover did not fix the problem. New diagnosis is that the water pump is noisy. I was quoted £150 to replace it - is this good? It's a "four spanner" task in the Haynes manual - has anyone ever done this themselves and lived to tell the tale?
Ben
bjw105 is offline
Old 24-09-2003   #6
Trader Rating: (0)
I haven't needed to do it, yet.
But it's timing belt off job... so they'll get another shot at getting it right[:(!]
The water pump bearing suffers if the belt is over tight.
Take it back to the place that did the belt and be a nuisance [:0]
What length of guarantee was there on their belt replacement workmanship??
Did they use the FIAT tool for adjusting the belt tension, or just do the 1/4 turn trick (which can get it too tight if you're built like Geoff Capes).
John H is offline
vB code is On
Cost of Marea 20v timing belt and tensioner change marea2111 Marea > Technical 5 28-04-2006 21:44
Tipo 1.6 timing belt - Urgent! Aharonsarussi Tipo 9 26-04-2005 18:21
timing belt on a '96 EL 2.0L andrew1620 Ulysse 0 22-07-2004 00:18
Timing belt cover/rubbing noise spiderman Cinq/Sei > Technical 2 12-03-2004 22:03
