| taffy git | have decided not to take car apart and route all new wires for the speakers, so im using the existing wiring and up-grading the speakers but how do you know which one is pos and which one is neg i dont want to wire them up the wrong way round and risk breaking the speakers the wires dont have any markings on them, apart from there colour, how would i find out which is +/- , i have looked in owners manual and stereo manual but no success ![]() thanks
__________________ Gaz Marea Weekender | ||
| Banned | Re: speaker wiring Black is nearly always earth so just assume that the other colour is positive. You can also go by light and dark (dark being negative). Dave
| | #4 | ||
| Banned | Re: speaker wiring You won't damage your speaker if you wire it up backwards. It should be fairly easy to tell when you have wired them up wrong. If in doubt, try the wires one way and then the other and choose what sounds best to you and then replicate that throughout the car. If I remember correctly my Mk2 has pink wiring for positive and dark purple wiring for negative. Dave
| | #5 | ||
| taffy git | Re: speaker wiring ah have just been to look and its a rainbow of colours ![]() but the standard headunit has a wiring diagram on it, so from that i will try and identify the right coloured wires
| | #6 | ||
| Banned | Re: speaker wiring hmmm its a nice idea in theory but doesn't always turn out that way. I tried that with my front door speakers and I couldn't find the same colour wires in the doors. After a bit of investigation I found out that before the wiring goes into the door it goes into a plug, and out the other side of the plug comes different colour wires. Nightmare!!! Dave
| | #7 | ||
| :) | Re: speaker wiring Gaz, put a voltmetre onto the speaker cables, when you have a positive PD then your red voltmetre probe is on the positive wire.
__________________ Now drives: '52 Megane 1.9dCi ![]() Past: Y-reg Fiat Brava JTD (Pale Blue) (2006) M-reg UNO (2003-2004) '51 Fiat Brava 80 SX (black) (2006) | ||
| | #8 | ||
| | #9 | ||
| Banned | Re: speaker wiring errr no I don't think you could bodge one together, but you never know. Maybe a job for google? ![]() Dave
| | #10 | ||
| :) | Re: speaker wiring Gaz you have one! A multimetre is another name. I am sure you have one, you have everything like that. It's a little box with a screen and usually two wires coming out of it Oh and a big selector knob.There's probably a very similar thing you can do to confirm, i.e. the size of the spades at the end, just I don't know it.
| | #11 | ||
| taffy git | Re: speaker wiring i havent got one of them, i want one though, they sound cool ![]() spades are same size looks like i will just have to test them, fire extinguisher at the ready ![]()
| | #12 | ||
| :) | Re: speaker wiring Go buy one, a few quid from maplin ![]()
| | #13 | ||
| | #14 | ||
| taffy git | Re: speaker wiring used to use them in school ![]() will go pop to local maplin am in no real rush, have still got my standard speakers what else they used for, looks like something you would see on star trek
| | #15 | ||
| :) | Re: speaker wiring Lots of things, most will measure voltages from say 0-1, 0-2, 0-10, 0-20, 0-100 etc. Some measure current for you (amps), they can check for continuity, i.e. test whether a switch is open or closed in a certain way, whether a fuse has blown etc. Some has transistor testers, some can allow measurement of temperature even. You get the idea.
| Cheap sound deadening success and speaker install | alexGS | Uno > Technical | 11 | 05-07-2005 11:40 |
| Mk2 Punto Front Speaker Wiring | blacka01 | I.C.E | 2 | 07-10-2004 15:53 |
| Rear speaker wiring? | ScottieCinq | I.C.E | 3 | 25-05-2004 20:02 |
| Punto rear speaker wiring | djfixter | I.C.E | 3 | 05-05-2004 22:18 |
| Punto Speaker Wiring | chris2009 | Punto > Technical | 2 | 15-12-2003 03:31 |
