| Coolant level I thought I couldn't see the coolant level on my old Punto because the bottle with min/max on was so dirty and you cannot reach it to clean. But my new Punto is exactly the same even though its brand new & bottle is clean I can't see where the coolant comes upto. Any tips for how you can see it? Also now I'm back with A/C is the handbook guide of 10 mins once a month OK to follow in the winter or should it be a lot more regular? Cheers
| Was VXR enough :( | Re: Coolant level My coolant bottle is slighty dirty, but if I give it a wobble I can usually see where the level is
__________________ Fiat Punto Active Skoda Fabia vRS Vauxhall Astra VXR SEAT Ibiza 20VT FR Renault Clio 182 &Honda CB600FA Hornet | ||
| | #3 | ||
| Re: Coolant level I'm scared to wobble it too much in case it disconnects something!
| | #4 | ||
| What's the worst that can happen? | Re: Coolant level Just bounce the car and I can see mine - if not whack a bit of paper down there see what length you can fit in before it hits the water - then compare it with the outside of the bottle
__________________ "The new rules are very simple. The FIA will keep them to themselves until such a time as Ferrari needs them" - Patrick Head | ||
| | #5 | ||
| Join Date: Oct 2003 Location: buxton the land that time forgot
Thanks: 1 Trader Rating: (0) | Re: Coolant level yeah if you cant see it use something to stick inside and see how far up it is wet.
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm | ||
| | #6 | ||
| :) | Re: Coolant level Best method I have always found is when it's cool, take the lid off, use a small torch to shine down, you can now see the level perfectly.
__________________ Now drives: '52 Megane 1.9dCi ![]() Past: Y-reg Fiat Brava JTD (Pale Blue) (2006) M-reg UNO (2003-2004) '51 Fiat Brava 80 SX (black) (2006) | ||
| | #7 | ||
| Re: Coolant level I reckon The Negotiators method sounds best, I'm not risking dropping a length of paper in the bottle, I just know thats what I'd do!
| | #8 | ||
| What's the worst that can happen? | Re: Coolant level That don't work on my punto because it's a long tube down to the tank - you can't tell whether it's at the full mark or not from inside. Might be different on different cars though. At the end of the day it can't be that hard.
| | phil_harry | Cinquecento / Seicento | 10 | 14-04-2005 19:36 |
| | Carltonleon | Stilo | 0 | 28-02-2005 10:38 |
| | Punto Mad | Punto | 8 | 01-10-2004 15:06 |
| Electronic Oil Level Indicator | Lou | Ulysse | 2 | 12-05-2004 19:38 |
| | Sando | Cinquecento / Seicento | 5 | 05-01-2004 20:22 |
