| Remote Central Locking I have a Fiat Punto S, which doesn't come with central locking. I would like to install remote central locking and have my doors delocked, due to my car being broken into via the locks a fortnight ago. However, I have been looking for a remote central locking kit and all I can find are the upgrade kits to central locking. Are there remote central locking kits out there that you can put into a car without the standard central locking? Wrighty
| Banned | Re: Remote Central Locking Hey, You can get a central locking kit and remote locking kit from ebay pretty cheap. You cannot fit a remote locking kit without the solenoids that come with a central locking kit. The remote locking works by replacing the command module from the central locking kit with one that works by remote. I think you can get both together off of ebay for around £30, not bad and you are guaranteed that they will be compatible (in theory). Dave
| | #3 | ||
| Re: Remote Central Locking I have seen an item on ebay that I believe is suitable for my car. Just a reminder, i dont have central locking and would like to install Remote Central Locking, is this item suitable for my car? HTML Code: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=7964760882
| | #4 | ||
| Re: Remote Central Locking why not just get the components off of a set of sx doors from a scrappy... at least then you know that it all should fit and you'll be able to install electric windows at the same time..
| | #5 | ||
| Re: Remote Central Locking only additional thing to buy might be a remote to operate it
| | #6 | ||
| Re: Remote Central Locking Then you have to get the doors all filled and smoothed and sprayed.....lot cheaper not to keep out expensive in your car in the start
__________________ Ghetto Moose - Running : 145BHP ,Punto GT2, BP270 Piper Fast Road Cam, Lemans DVK005 Dump Valve, Drilled Airbox with K&N panel filter. Next - De-Cat | |||
| | #7 | ||
| Re: Remote Central Locking My car was broken into a fortnight, via the lock, and so i have a lock that doesn't work and a door with a nasty dent in it, this is the only alternative I can think of. I guess that installing remote central locking will also increase the value of the car aswell. I have just been reading through a recent post and have been looking on the Maplin website, which is quite helpful and I am hoping to buy the full kit on there. As for the filling in the wholes, and spraying the doors, im lucky enough to have a friend who is a mechanic so it wont be too expensive
| | #8 | ||
| Re: Remote Central Locking go on go for it. it'll make the car mint. i got a remote central locking kit off ebay for £20 couple of months ago. well worth the cash.
| | #9 | ||
| Re: Remote Central Locking How easy are these to fit? how would I go about it on my MK2 punto?
| | #10 | |||
Mechanic or a body shop worker? I a mechanic fixes engine parts, body shops fills and sprays
__________________ Ghetto Moose - Running : 145BHP ,Punto GT2, BP270 Piper Fast Road Cam, Lemans DVK005 Dump Valve, Drilled Airbox with K&N panel filter. Next - De-Cat | ||||
| | #11 | |||||
I have been advised by a member on here to purchase this item: http://cgi.ebay.co.uk/ws/eBayISAPI.d...MakeTrack=true Anyone think it is any good and ok for me? baring in mind i dont already have central locking and i am not just looking for an upgrade, i need the whole shabang!
| | #12 | ||
| Re: Remote Central Locking on the MK1 it sits behind a panel in your glove box. all you do is attach it on and bobs your uncle. dont know if its the same on the MK2
| | #13 | |||
I then got a toad alarm fitted and the guys in the shop did that bit for more, so now have remote central locking and its all alarmed. The kit i got of ebay ages ago and cost me about a 20squid and i think then the alarm was a fair bit but better save than sorry. Does the trick. | ||||
| | #14 | ||
| can go much lower | Re: Remote Central Locking I also have a Punto S, which didnt come with any Central Locking I got the relay and motors for the central locking from the local scrappy for £10 and then got the upgrade kit for £50. it works really well, although fitting was the most difficult part, taking around 2 hours... I personally would avoid the "universal" kits like the plague, as they are an absolute b1tch to fit, I tried that approach before opting for the Punto one from scrappy, miles easier... 3/5 door motors are the same, and there are only 2 motors to worry about as the boot is not part of it... Hope this helps...
__________________ ![]() CinquePunto - Five Point Photography - Adam | ||
| | #15 | ||
| can go much lower | Re: Remote Central Locking If you're still looking, check this out, 2x central locking motors and locks, replace the whole unit... http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
| BOO Bargains - Remote Central Locking Kits | wimmy | Auction Watch | 8 | 14-01-2008 01:18 |
| Fitting Remote Central Locking Mk3 Punto | Russell | Security | 5 | 01-06-2005 23:22 |
| | davemarsh | Punto | 2 | 07-05-2004 16:59 |
| | m a t t | Cinquecento / Seicento | 1 | 25-03-2004 03:41 |
| | arc | Cinquecento / Seicento | 6 | 08-10-2003 22:01 |
