The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 10-02-2005   #1
Trader Rating: (0)
Punto (second version) Dualdrive problem
Hello dear!
I' m new on this forum for Punto (I wrote some months ago on Uno forum), and I'm going to ask you help for a little problem on my mother's Punto.
It's a 1.2 8V engine, and dualdrive servo assistance on turning wheels (I can't say it correctlly in english).
This car experienced a problem with its electrical servo system. Inface, sometimes, servo assistance completely vanishes (steering becomes very hard to turn) and a red light turn on on control panel (light of steering). The problem finishes by turning OFF ignition key and engine, and re - turning it ON.
This problem happens not during the normal going on streets, but it happens only when she parks the car, in other words it happens if someone turns wheels left and right and left and right more than one or two times.
I know that servo problem is not an unknown problem for Dualdrive, but I don't know anything precise about it.
Can someone help me??
Thanks a lot!!!
andre79ge is offline
Old 10-02-2005   #2
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Punto (second version) Dualdrive problem
I take it your talking about the electric powered steering?
Normally this is due to one of three things;
1)Steering ECU (requires steering ECU mounted on the column)
2)Steering torque motor sensors (requires full steering column)
3)Vehicle speed sensor (there is a wiring section available to cure this)
Look at these previous posts but I 'm sure a trip to the Fiat dealer will be required in your case.Normally the VSS wiring loom section is tried first as its te cheapest (by far) option!
http://www.fiatforum.com/showthread....steering+light
Hope this helps
T14086 is offline
Old 10-02-2005   #3
Trader Rating: (0)
OK, thanks you!
I know it's not an easy problem to solve: steering is very important!
I'm thinking to go to a Fiat technician.
Thanks,
Andrea.
(T) Solution to Punto 75 mk1 Engine Problem Tziallas Punto 4 24-03-2008 18:35
(T) Clutch / Gearbox problem with 1999 Punto Gorskar Punto 7 02-10-2004 11:15
(T) Wierd Electrical Problem With My MK2 Punto nawtwrong Punto 8 24-09-2004 17:50
(T) Punto 12. 8v problem... broadfield Punto 2 31-10-2003 03:09
(T) Punto 55SX Temperature problem!?!? nodgers Punto 5 26-10-2003 22:38
