The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 14-07-2003   #1
Trader Rating: (0)
Fuel Injector Warning Light - 1.1 55SX
My son has just completed his first motorway journey(250 miles) in the above (L Reg) & reports that the dashboard injector warning light comes on at 80 mph and goes off again at 65 mph, with no noticable change in performance.
I've recommended some injector cleaning fuel additive, but now on reading this forum am inclined to think it may be the EGR sticking (probably closed).
So, questions:
a) Is this causing any damage to the engine?
b) Does an L reg 1.1 Sx actually have an EGR (the workshop manual is at his end of the Motorway, not here!)- because when the car was here I had the airbox off to fix a rocker cover gasket leak - never noticed any 'barrel-shaped object' (but then I wasn't looking for it)
c) What are the chances (in anyone's personal experience)of cleaning up the EGR compared to needing to buy a new one?
all things must pass.
Matts Dad is offline
Old 15-07-2003   #2
Trader Rating: (0)
:)hi i think the problem is the lambda sensor i have the same car and the same problem i changed the lambda sensor and that corrected it. i have been told you can clean it with meths and compressed air. but its easy enough to repair. and how many revs does the car do at 70mph
magikbilly is offline
Old 15-07-2003   #3
Trader Rating: (0)
Thanks for that - will get back to you on revs at 70 (need to ask Matt!).
Did you change the lambda sensor yourself, & if so do you need special tools or gasket stuff, or anything special. Did you not try to clean it first, (or did you try & fail?).
Matts Dad.
Old 15-07-2003   #4
Trader Rating: (0)
i just replaced it myself they are about 65 from fiat but prob cheaper at a garage i didnt clean it as there is more chance of it happeneing again i just used a spanner and it worked fine you can tell the difference once its changed. let me know once you have changed it.
Old 16-07-2003   #5
Trader Rating: (0)
Ta for that. WIll report back when sorted - may try to validate it is the Lambda first by ECU diagnostics readout @ Fiat garage though.
Old 16-07-2003   #6
Trader Rating: (0)
i wont go to fiat if i was you as if the red light goes out they wont pick it up. save your 30 quid and just get a lambda sensor. i done what you said youare going to do and it was a waste of 30 quid
Old 17-07-2003   #7
Trader Rating: (0)
The 1.1 doesn't have an EGR, it will more likely be a fueling problem. Fill up with Optimax as often as you can (it contains cleaning agents) but it does sound like a lambda problem.
I personally would leave it until (IF) it gets worse, if the chance arises you could try to clean the sensor and the connector (carefully with no thinnners).
Golden rule - Never let Fiat work on your Fiat, they know nothing about them.
Evil-Punto is offline
Old 21-07-2003   #8
Trader Rating: (0)
Ok, UPDATE:
I had sent him off with a full tank of Optimax before he first reported the light coming on last week. That journey used only 1/4 tank. He's been back home again this weekend & now gone back. He reports that the injector light has stayed off on both these subsequent journeys, so my current assumption is that the Optimax has done it's work (eventually!).
Thanks to all who gave advice - & it looks as though 'if it ain't broke don't fix it' are the wisest words.
Magikbilly - he said that 70mph was around 4000 rpm (working from memory, not a test). Sound right?
Old 22-07-2003   #9
Fat pigeon... APPLE!
JonnyBoy's Avatar
Trader Rating: (1)
JonnyBoy has donated! United Kingdom
70mph@4000rpm is about right, my '94 5-speed 55SX does the same. Although Optimax failed to fix the same prob on my car!
FIAT: Fix It Again Tomorrow...
JonnyBoy is offline
(T) fuel injection warning light and stalling crow1 Punto 11 24-10-2007 01:17
(T) Fuel Injector Warning light karmapolice Punto 4 10-01-2006 01:44
(T) Water in fuel light Tapbuster Punto 2 22-12-2003 00:25
Fuel Injection Light John Roberts Lets Talk FIAT 5 03-09-2003 04:21
(T) Fuel emission problems / Injector light FrightNight Cinquecento / Seicento 27 13-08-2003 16:53
