The FIAT Forum
Celtic Tuning - ECU Performance Remap Specialists
Go Back   The FIAT Forum > FIAT Cars > Punto > Punto > Technical
Old 15-11-2004   #1
Trader Rating: (0)
75SX - Replaced sensor, but still won't start
A few days ago a fault was found at the crank shaft sensor and so the guy at the garage repaired the wiring. But recommened I repace the sensor in the future, if ever the problem re-occurs.
The car was working perfectly for a few days. But only yesterday did it start playing up again. I got out to start the engine and it wouldn't start. I knew straight away it was the crank shaft sensor which had gone.
I thought I'd leave it for a couple of hours. I used the red key this time, and voila ! it fired up, left it running for a minute or so, switched off the engine and used the same key to start up again, but it wouldn't start.......
Well the car has been at the garage today and the mechanic has replaced the sensor but the car will still not fire up. He's check the leads/spark plugs and he suggests there's no spark there somewhere.
He mentioned something about opening up a module....not sure what this is.....can anyone suggest where the fault could lie or what I could do ?
P.S. battery is full, starter motor and alternator perfect.
shabz1981 is offline
Old 17-11-2004   #2
Trader Rating: (0)
Re: 75SX - Replaced sensor, but still won't start
hi mate where did u get the crank sensor from???
beechey is offline
Old 17-11-2004   #3
Trader Rating: (0)
Hi
I ordered the part from my local Fiat dealer. It took a few hours for delivery.
P.S. Car is now at my Fiat dealer who have run a diagnosis and found the ECU is showing up as an error. They mentioned that would need to get a new blue key cut and code it up.....not sure what they are going to do with the car, would anyone know ???
Old 17-11-2004   #4
Trader Rating: (0)
sounds too me like the first mechanic did a mis-diagnosis and its something wrong with you code system.
-=[Punto sporting 1.2 16v]=-
-=[Ex-fiat tech]=-
kebab is offline
Old 18-11-2004   #5
Trader Rating: (0)
why do they need to get a new blue key? do you not already have one?
whitey is offline
Old 18-11-2004   #6
Trader Rating: (0)
he probly only has the one red and one blue key, the garage will want too recode the ecu too start with and this can only be done properly with 2 blues and a red.
-=[Ex-fiat tech]=-
kebab is offline
Old 22-11-2004   #7
Trader Rating: (0)
Smile Re: 75SX - Replaced sensor, but still won't start
Hello people !
After 8 days of no car, I finally got it back today from my Fiat dealer. They got the car starting, said it was an ecu error.
Anyway this is how it was put on my invoice. Anyone shed any light into what exactly was carried out.............
Placed on examiner fault codes present for pressure sensor. Injector control, coil 1 and coil 2, Unable to delete errors; removed engine ecu and sent for repair; refitted ecu and tested - o.k.
It cost me about £120 in total. ECU test was £60, whilst to obtain a code and labour made up for the rest.
vB code is On
Help! 1995 M doesn't start! Martina Punto > Technical 18 15-11-2004 23:07
Punto 75SX '99 - 2 problems zokipet Punto > Technical 0 08-10-2004 06:27
Fiat Punto 75SX '99 2 problems zokipet Punto > Technical 0 07-10-2004 14:09
Punto 75SX performance puckapunto Punto > Technical 0 23-04-2004 20:59
Cold Start spray fixed it . How ? Oilslick Punto > Technical 5 02-12-2003 03:05
