The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 10-09-2008   #1
Trader Rating: (0)
bearing and seal change help required.
punto with slipping clutch, removed transmission, found oil from gearbox on pressure plate. Gearbox input shaft has slight movement and oil can be seen on shaft. Need information on replacing bearing and oil seal on input shaft, how to strip the box to access the bearing and the torque settings on rebuild. Punto 1.2 8V year 2000 5 speed box.
Can anyone help please! Dad'llfixit.
Dad'llfixit is offline
Tags
gearbox, input shaft, rebuild, torque settings
(T) back wheel bearing change bossdogg Marea 4 05-07-2008 00:44
(T) After rear bearing change - ABS failure lammy1 Stilo 27 10-10-2007 21:29
Squeaky front wheel after new bearing change? contractor Panda (Classic) 14 13-06-2007 21:37
(T) How to change cambelt tensioner bearing uncle Punto 1 22-03-2007 18:45
(G) Wheel Bearing Change MotorWorldChink Cinquecento / Seicento 6 24-09-2004 22:59
