| Radiator Cooling Fan Noise I have a Punto Mk2 and recently it began making an intermittent noise, I have noted when this happens and discovered it is when the electric cooling fan is working. I assume it is dry bearings and wondered if there is anything I can do to lubricate them or failing that where is the best place to purchase a replacement part? Thanks
| Re: Radiator Cooling Fan Noise can get a replacement fan from www.shop4parts.co.uk To lubricate it try good old WD40 or some spray white grease | |||
| | #3 | ||
| Re: Radiator Cooling Fan Noise Thanks Mdeko I was a bit worried about the WD40 because I have heard it dries out the bearings and may be good in the short term but cause more problems later - any thoughts/guide - also what is white grease and where would I get it? Cheers
| | #4 | ||
| Re: Radiator Cooling Fan Noise I got a can of white spray grease from maplins. WD40 is a short term solution, white grease will last longer. | |||
| | #5 | ||
| | #6 | ||
| Outsider. | Re: Radiator Cooling Fan Noise I'd get a new rad fan asap. My rad fan started making a funny noise a while ago, then today it just stopped working all together. Luckily I have a temp gauge, so when I saw it rise to 3/4 I just stopped, switched the engine off and let it cool. If it does totally pack in and you end up overheating.. it'll end up being a much bigger bill | ||
| | #7 | ||
| Re: Radiator Cooling Fan Noise Thanks MattMk1 where did you get your replacement from and roughly how much was it please?
| | #8 | ||
| Outsider. | Re: Radiator Cooling Fan Noise i'm letting the garage handle it, seen as it's MOT time anyway and i can't be bothered with rotten nuts/screws/fiats. but shop4parts will have what you are looking for - a mk1 fan was about £60. | ||
| | #9 | ||
| MAY44T | Re: Radiator Cooling Fan Noise For Punto parts try a chap called Ricky...07745635908 tell him Mayat gave you his number. Been dealing in punto for YEARS!
__________________ Breaking Cinq SX 899cc & Seicento Abarth. See classifieds! or PM me | ||
| Tags |
| cooling, fan, noise |
| | jannen | Bravo / Brava | 2 | 26-03-2008 20:30 |
| | gaz.d | Punto | 14 | 17-09-2006 19:03 |
| | TonyTantrum | Punto | 4 | 02-05-2005 16:58 |
| | hopbackuk | Marea | 2 | 03-12-2004 23:20 |
| | bellamys | Bravo / Brava | 1 | 20-04-2004 04:15 |
