The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto > Punto > Technical
Old 19-07-2008   #1
David_1984's Avatar
Trader Rating: (0)
Rattle when I reach 40mph.
Last week I noticed a rattle everytime I change gear at 40mph in second gear to third. The noise is coming from the drivers side at the front of the car.
Does anyone know what this could be?
Is it anything to worry about?
David_1984 is offline
Old 20-07-2008   #2
A Panda with Gadget's
Most Easterly Panda's's Avatar
Trader Rating: (0)
Most Easterly Panda's has donated! United Kingdom
Re: Rattle when I reach 40mph.
Possibly the exhasut. I know they can rattle like hell if they've been knocked and the mounts are out/gone.
Jon.
Bright in White... ...Bright at night!
Look at those spots and the 240 watt of 4 Halogen bulbs!
Originally Posted by b1g1an View Post
You need to twist as you pull, just twisting then pulling isn't enough.
Originally Posted by Jai View Post
grip the meat, loosen the throat, relax and slide it in
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Panda's is offline
Old 20-07-2008   #3
David_1984's Avatar
Trader Rating: (0)
I went fishing on a river last sunday and I had to drive on a track, grass on either side and grass in the middle. (And getting my tyres extremely mucky with mud and cow-muck) I remember when coming back and hearing a scuffing noice from the bottom of the car. I got out and looked under the car and there was a peice of grass stuck underneath. (Had to get out cus I had to see what route I was going to take to avoid going in to a muddy puddle lol)
When I had my engine oil changed, Kwik-Fit said that the exhuast was going, there was a slight hole in the front pipe......They car does blow a tiny bit. I'm not going to replace it until it gets worse.
THe noise also could be the tyre trim!! ?
Old 20-07-2008   #4
Trader Rating: (0)
Could be a tyre trim, but I doubt it personally. If its rattling then its loose, and if it loose then it would probably have fallen off by now.
Have you not thought about patching up the hole on the exhaust if it's only a small one at the mo? Could save you a few quid
Jon.
Old 24-07-2008   #5
David_1984's Avatar
Trader Rating: (0)
Yes I have thought about patching the hole up, but as I said, its not that urgent at the moment. It passed its MOT ok, so the exhaust must not be going yet.
I will have to try taking the trim off and go for a short drive and see if I hear anything then.
vB code is On
ePER - Unable to reach Lou Ulysse 2 31-03-2008 10:53
40MPH rattle O/S front wheel arch Ihatemyfiat Stilo > Technical 8 15-03-2008 17:29
Slight shaking at 35-40mph Suz359 Punto > Technical 7 13-07-2007 14:36
Do pandas reach a state of enlightenment?? posh pandas Panda (Classic) 24 03-02-2007 18:36
uno turbo will this one reach 3k dave Auction Watch 13 06-04-2004 00:59
