The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto > Punto > Technical
Old 04-07-2008   #1
can go much lower
CinquePunto's Avatar
Trader Rating: (0)
CinquePunto has donated! United Kingdom
mk2 sporting won't start
Right, got home last night, all fine. Went to move car after about 2 mins and nothing, turned to first click, dash lights came on, then turned to start and clicked, everything went off and the clock reset itself.
jump started off dad's car fine. Left for 5 mins with engine running. Turned it off and tried again, same thing, absolutely nothing, starter motor didn't do anything.
Charged battery overnight on the mains charger. put it in the car this morning and again, nothing.
Any ideas? or is it a case of calling out the Auto-Electrician to look at it?
CinquePunto - Five Point Photography - Adam
CinquePunto is offline
Old 04-07-2008   #2
Steve
Rockbottom's Avatar
Trader Rating: (0)
Rockbottom has donated! United Kingdom
Re: mk2 sporting won't start
How old is the battery? Could be a dead battery, what voltage do you get if you put a multimeter on it?
Also check the battery terminals are on securely, making a good connection.
GSR/Red Dot Remapped Punto 1.9 JTD
Running 124.8bhp & 195.3lbft torque
My cars thread
Rockbottom is offline
Old 04-07-2008   #3
Bandido A Maneira!!
bandido41's Avatar
Trader Rating: (1)
bandido41 has donated! South Africa
Try jump starting it off another car if it doesnt start then it will be the starter thats the problem try giving it a tap on the solenoid to see if it makes a difference
All the arms we need are for hugging!
bandido41 is offline
Old 04-07-2008   #4
can go much lower
Trader Rating: (0)
it's 12.6V on a multimeter. Tried starting off dads car (as in original post...) and it started first time.
I just don't understand how the battery can die in 2 mins.
Old 04-07-2008   #5
__________
dave's Avatar
Trader Rating: (9)
dave has donated! Saint Kitts and Nevis
they just do, get a new one. my battery die in the punto but still work for a year after in the panda
i pay £25 from motor factors for a new one that is more powerfull than the original speedgear one, but a bit shorter so needs a bit of wood under it
Binki
dave is online now
Old 04-07-2008   #6
can go much lower
Trader Rating: (0)
took it to halfords and they did a test on it...
2 of the cells are shorting, it's putting out a grand total of 3 amps. lol
Trying to get a battery for as cheap as poss... Hal-frauds wanted £80!!!
vB code is On
MK2 Sporting won't start... Guaje7 Punto 3 16-04-2008 14:30
Black abarth kitted mk2 punto mk2 sporting, A50 puntokris Spotted / Was It You? 1 25-03-2008 22:11
Mk2 Punto will not start gmjones Punto > Technical 14 30-08-2007 23:46
crashed mk2 won't start, HELP!!! trialbiking Punto 8 24-05-2006 20:53
Mk2 Failing to start until warm. nex97 Punto > Technical 4 27-01-2005 08:23
