The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 02-06-2008   #1
Trader Rating: (0)
ecu problem
hi everybody can anyone help me i have fitted a new ecu but after fitting car runs rough the back window wiper is on constantly and the side lights flash on and off is there something i have done wrong
kennybird is offline
Old 02-06-2008   #2
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: ecu problem
what car is it?
p.s. post is in wrong section.
T14086 is offline
Old 02-06-2008   #3
Trader Rating: (0)
Re: ecu problem
fiat punto w reg 1.2 8 valve
Old 02-06-2008   #4
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Re: ecu problem
And this has only happened since fitting the ECU? why did you fit ECU in first place?
T14086 is offline
Old 02-06-2008   #5
Trader Rating: (0)
Re: ecu problem
the code light came on and car would not start
Old 02-06-2008   #6
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Re: ecu problem
are engine/body earths good?
T14086 is offline
Old 02-06-2008   #7
Trader Rating: (0)
Re: ecu problem
yes everything was working fine then code light came on and when i change the bit behind fusebox bit on the engine with the 2 plug things on it and the ignition barrel it just went like herbie the replaced bit came off same model and year
Old 02-06-2008   #8
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Re: ecu problem
you mean you changed the body computer (that clips onto rear of fusebox)?
T14086 is offline
Old 02-06-2008   #9
Trader Rating: (0)
Re: ecu problem
yes that and barrel and bit in engine
Old 02-06-2008   #10
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Re: ecu problem
100% from car of same year/model?
T14086 is offline
(G) ECU problem? jerhawk Bravo / Brava 3 08-05-2008 16:13
(T) mpi sei ecu problem? / remap time? / Virgin Ecu? ronnieronson Cinquecento / Seicento 20 10-02-2008 15:15
(T) im sure you've had this before but ECU PROBLEM! swintonblade Punto 3 20-09-2006 23:09
(T) Possible ECU problem peter200 Marea 1 14-07-2006 12:44
(T) ECU problem? paul t. Punto 13 20-08-2005 20:39
