The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 22-04-2008   #1
Trader Rating: (0)
Punto Mk1 Gear Problem
Hello.
Have an N Reg Punto 1.1. I havnt used the car in a while, so drove it round the block, the gears were a bit stiff but went in without much trouble.
Two days later, the gears wont go in at all. And the reverse will growl when ever I try to put it in.
For some reason, all the gears go in fine when the car is turned off. Am so confused. Cannot drive it at all at the moment. Sob.
Please help!!
Ajv2809 is offline
Old 22-04-2008   #2
Trader Rating: (0)
Re: Punto Mk1 Gear Problem
Thats a tell tale sign of a faulty clutch.
Is it hydraulic or cable? (if hydraulic the system could need bleeding, if its cable the cable may need adjusting)
53 reg Mk2b 8v Lagoon Blue . . .UKT support
Mdeko is offline
The following user says "Thank You!" to Mdeko for this useful post:
Ajv2809 (22-04-2008)
Old 22-04-2008   #3
Trader Rating: (0)
I have no idea. Am guessing cable. But only because its a basic model and sounds cheaper.
Ajv2809 is offline
Old 23-04-2008   #4
Trader Rating: (0)
No, your car has a hydraulic clutch. Try bleeding it, if that doesn't cure it probably needs a new clutch.
greasemonkey is offline
Tags
gear, help, mk1, problem, punto
(G) My 03 Punto clutch/gear problem davybreen Punto 4 10-12-2007 01:01
(T) punto gear linkage problem mckeown.thomas Punto 6 18-11-2007 23:48
(S) Gear Knob on an mk1 punto? YeTeP Punto 1 20-12-2006 18:20
(G) replace your gear knob punto mk1 evol1 Punto 2 25-04-2006 10:23
(S) How to remove Gear knob on mk1 punto??!! rickv_60sx Punto 20 05-03-2006 18:25
