The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto > Punto > Technical
Old 22-04-2008   #1
Trader Rating: (0)
Punto mk2 1.2 8v Petrol Smell And Water Noise
Hi all, this is my first post. I am also completely new to any car DIY so very basic answers would be appreciated.
I have a punto mk2 W-reg (2000) 1.2 8v and have been having a couple of problems for quite some time. I realise there are quite a few threads about these issues but i am really desperate for the answer as they are driving me nuts. Also i dont want to just ignore them and possibly cause damage.
1. Petrol smell - very strong smell of petrol in cabin only, and only when set to take in outside air. Recirculating the air cures the simptoms but obviously not the problem.
2. Water noise - I originally thought this was the reservoir thing at the back of the engine bay that filled up with water because the holes at the bottom were blocked with gunk but i cleared them out and still have the problem.
It only happens when cold and when the revs are increased. Also it doesnt matter whether or not it has been raining.
It seems like the system needs bleeding but could you give me any advice on anything else that it could possibly be and how easy/cheap it would be to get done. Also would this problem re-occur after simply bleeding the system?
Daniel
drm08 is offline
Old 22-04-2008   #2
Trader Rating: (0)
Romania
Re: Punto mk2 1.2 8v Petrol Smell And Water Noise
hey I had petrol smell in the cabin and the mecanic fixed that long isolation rubber (marked in the picture) because it was pressed by the washer hose. He pushed the rubber towards the windshield and switched the clams position that holds that little washer hose.... (sorry for my bad english).
and about the running water noise... it's air in the coolant system...
I hope it helps
Raducu is offline
Old 23-04-2008   #3
Trader Rating: (0)
But was your fuel smell only with heater on etc? because surely that piece wouldnt cause that problem? Not that i dont believe you, just cant picture that....
Thanks for the reply
drm08 is offline
Old 23-04-2008   #4
Trader Rating: (0)
Romania
yap only with the heater on... but it was burned fuel smell, he also said that maybe the exhaust system is releasing the smoke near the engine... The main problem is that when I arrive to the mecanic , my punto is suddenly alright, no smoke, no leaks, no problem (i had some o ring problem). But anyway I have no more smell in the cabin, and I still have the runnig water sound, sometimes between CD tracks.
p.s.: I have left my punto 3 days in service shop so that the mecanic could see the problem
Raducu is offline
Old 23-04-2008   #5
Trader Rating: (0)
I have checked that rubber seal and i am almost positive that it is having no effect whatsoever. So i am still stumped. I guess its probably not the fuel filter as this is at the rear of the car?
By the way are the thin blue pipes the fuel pipes?
Thanks again.
drm08 is offline
vB code is On
MK1 Fiat Punto Petrol Smell dark_knight Punto > Technical 28 06-03-2008 18:05
1994 Punto 55- Petrol smell Fridge Punto > Technical 1 08-02-2008 13:33
Petrol Smell and Noise from front left wheel area! MoDiFiEd Punto > Technical 2 11-01-2007 10:58
Punto Mk1 petrol-smell while driving gradinka Punto > Technical 4 28-07-2005 17:48
Punto MK2 Sporting - petrol smell??? rongo Punto > Technical 4 19-04-2005 22:18
