| do you use oil additives Just wondered' as halfords has a shelf full being brought by weekend mechanics ![]() You might want to read this first http://www.fordscorpio.co.uk/snakeoil.htm
| | #2 | |||||
| Re: do you use oil additives
.. anything, spend the money on good engine oil..one of the best things you can do to your car is change oil&filter more often a lot cheaper in long run
| | #3 | ||
| Re: do you use oil additives Just hope it will save some of the young uns some cash p.s i am a mechanic @ have been for 29 years i worked on renault 5's with column change, my first car was a renault 17 TL
| | #4 | ||
| Re: do you use oil additives i used to do all my own servicing & most of mechanicle stuff myself but i,m an old git now so i cant get under the car any more doing anything to the car now is a major hassle to me due to aches & pains eyesight not what it used to be etc etc .jings no much wonder i,m a moaning old git getting back to the additives though, i do hope the young team on here will take note, and repeating myself again using good oil & g change more oftenhappy motoring everyone
| | #5 | ||
| Chasing Cars | Re: do you use oil additives Total waste of money. A 'good' fuel system cleaner every 6months is worth it such as forte. That reminds me mine needs doing
__________________ ![]() Present: 05 Punto Sporting 1.4 16v | ||
| | #6 | ||
| Re: do you use oil additives Very enlightening. Thank you.
__________________ 2000 Punto 2, 1.9 JTD 5 door with 222222 Km//138222 Miles. This will stop anyone from tailgating you anywhere that French is spoken......Je ne suis pas un chein. Ne mettez pas votre nez dans mon cul, svp. | |||
| | #7 | |||
| Bravo 1.8 HLX FTW | Re: do you use oil additives
| | #8 | ||
| Rossi's Love Child | Re: do you use oil additives the only thing ill ever put in my oil filler cap is oil!
| | #9 | ||
| Re: do you use oil additives The sense of putting PTFE into a setting where it's likely to see the temperatures it sees in the combustion chamber never made any sense to me. A place I was working at had a major incident when a filter housing caught fire. It was an active charcoal filter, and that in itself isn't a problem. The problem was that there were small amounts of PTFE in the mixture. Now, look at DuPonts MSDS for Teflon (PTFE) and look at the possible decomposition products and you will see hydrogen flouride. Hydrogen flouride, also known as hyd ouric acid!!!Now, have a look at an MSDS for hyd ouric acid and see what a nasty little beast THAT can be. Here's a hint, it's used for glass etching as it's the only acid that will dissolve solid glass!From a HF MSDS, (note the capitalization is on the MSDS, not mine!) POISON! DANGER! CORROSIVE. EXTREMELY HAZARDOUS LIQUID AND VAPOR. CAUSES SEVERE BURNS WHICH MAY NOT BE IMMEDIATELY PAINFUL OR VISIBLE. MAY BE FATAL IF SWALLOWED OR INHALED. LIQUID AND VAPOR CAN BURN SKIN, EYES AND RESPIRATORY TRACT. CAUSES BONE DAMAGE. REACTION WITH CERTAIN METALS GENERATES FLAMMABLE AND POTENTIALLY EXPLOSIVE HYDROGEN GAS. So, tell me again how it's a good idea to put anything containing PTFE into an engine?
| | #10 | ||
| Bravo 1.8 HLX FTW | Re: do you use oil additives did anyone know that it was ici that discovered how to attach ptfe to metals to form non stick frictionless coatings they decided there was no use for attaching ptfe to metals and sold the idea to DuPont who later dubbed it Teflon and made millions selling cock ware lol and i can tell you that under no circumstances will ptfe attach itself to your engine under normal engine operating conditions i would say the friction loss and engine power gain in those tests on the article were probably due to engine wear we all know what new engines are like for the first 1000 miles take a wile to loosen up and a fiat fire with 100k on i can tell you is very nice and free
__________________ GOD of the the 5 Door Liberation Front ![]() Founder of the Heraldic Blue Bravo HLX Liberation Front ![]() Last edited by littlepip17; 08-04-2008 at 21:27. | ||
| Oil additives in engine or gearbox? | combwork | Multipla | 0 | 04-10-2007 02:50 |
| Oil additives | fiat_freak | Leisure Lounge | 2 | 30-03-2007 21:43 |
| Any use additives..? | peterp | Car Care | 3 | 18-04-2006 21:20 |
