| punto won't start no spark Hi, I have a 1.2 16v punto, which won't start, I have checked each lead and none of the spark plugs are firing. It is getting fuel. I have taken out and cleaned the crank sensor, is there any tests that I can do to find what has gone down. Any help will be much appreciated. thanks
| | #2 | |||||
| Re: punto won't start no spark
Do the checks on the coil guide http://www.fiatforum.com/punto-guide...cu-checks.html then suspect the sensor. It could be the connections and / or wires , if the sensor itself they're a pig to check , I went to the local scrappy .. usually plenty of Mk. 1's ! and easy to remove. good luck !
| | webhead | Punto | 2 | 04-01-2008 02:25 |
| | jamie1 | Punto | 2 | 07-10-2005 21:12 |
| | TheCarInfrontIsA-JTD | Punto | 4 | 29-09-2005 19:58 |
| | rickb | Cinquecento / Seicento | 4 | 28-09-2005 22:49 |
