| Hey everyone, just need a word of advice on my 1996 Punto 1.1i, its my first car so Im a bit of a novice. Ive noticed that oil doesn't last very long in my car, it doesnt leak externally, and if it does its minimal, but it seams to congrgate around the top of the engine?? The cars performance isn't really hindered by it, starts first time and drives well but does produce a burning oil smell when i push it to 100mph lol, which i know i shudnt be doing in a 1.1 but hey! The water doesnt leak, which leads me to think it can't be the head gasket? If it was the head gasket, I'm assuming there would be other leaks and there would be more problems caused?? The oil just seams to leak and spread around the top of my engine, and now the part located under the air filter is covered in oil...........wondering what people would suggest in my position?? Many Thanks
| Re: Oil Leak (Rocker gasket or head gasket???) Take the rocker cover off put a bead of instant gasket all the way round the head new gasket another bead of instant gasket then put the cover back on see if that cures it.pot of gunk will sort out the mess as well
__________________ Fix It Again Thomas!!![]() 1998 Fiat Punto 60 S 1.2L SPi Now Driving![]() 2006 Grande Punto Dynamic 1.2L 8V | |||
| | #3 | ||
| Bravo 1.8 HLX FTW | Re: Oil Leak (Rocker gasket or head gasket???) buy a new gasket and follow these instructions http://www.fiatforum.com/punto-guide...eek-later.html also have a look underneath the car and check the steel sump is not rusting through if your concerned about excessive oil usage these cars can start to burn oil if there not given a rite gut wiping half the time but at 100 in a 55 is about 5.5k rpm so no problems there lol ps you can't break these engines so don't worry about using the entire rev range
__________________ GOD of the the 5 Door Liberation Front ![]() Founder of the Heraldic Blue Bravo HLX Liberation Front ![]() Last edited by littlepip17; 30-03-2008 at 00:40. | ||
| | #4 | ||
| Re: Oil Leak (Rocker gasket or head gasket???) thanks for ya help lads, i replaced the rocker gasket today and sealed it well and truely tight, and jet washed the oil that had leaked over the engine away. I filled the oil up again, and for the first time since ive had the car I could get a reading on my dip stick (before it just looked like there was no oil in it at all!) so thats always and encouraging sign. had a look just now though, and it seams like the oil is seeping through the metal tank looking thing that is immediately beneath the gasket? (I havent managed to get a pic, but you have the air filter, then a metal lid, then the gasket, and then a metal base below it) And it seams to be seeping through that part?? But, since replacing the gasket, the car starts alot better and drives alot better, but just wish I could fix it once and for all as I worry alot and just think my cars guna die lol thanks again lads
| | #5 | ||
| Bravo 1.8 HLX FTW | Re: Oil Leak (Rocker gasket or head gasket???) the metal part below you speak of is the cylinder head it contains the camshaft and valves and is bolted to the cylinder block now i have seen one of these on a fairly new car that turned out to be pourus and was allowing oil to pass right through it but to properly diagnose this you need to get the hole engine properly clean and i mean really clean so you can say for sure were the oil is actually coming from also have you looked under the front of the car yet to inspect the oil sump it's always weird were oil can end up on engines due to the air rushing around the engine bay carying it about
__________________ GOD of the the 5 Door Liberation Front ![]() Founder of the Heraldic Blue Bravo HLX Liberation Front ![]() Last edited by littlepip17; 30-03-2008 at 11:29. | ||
| | #6 | ||
| Re: Oil Leak (Rocker gasket or head gasket???) I know when my head gasket went I had oil seeping out between the head and the block. Mine was seeping out from No.1 cylinder on the left hand corner at the front. A noise like an old man wheezing around the leak could indicate a blown gasket as well. Do you have any problems with overheating? Check around your oild filter as well as the sump as already mentioned. Best bet is to get a degreaser such as gunk or Autoglym Engine & Machine cleaner & an old paint brush. Spray it all over the oily bits work up and rinse off. Once you have everything off you can see where the new stuff is coming from. Then stick a pic up and we will see what we can do
__________________ Fix It Again Thomas!!![]() 1998 Fiat Punto 60 S 1.2L SPi Now Driving![]() 2006 Grande Punto Dynamic 1.2L 8V Last edited by Thomas_Si; 30-03-2008 at 16:47. | |||
| | #7 | ||
| Re: Oil Leak (Rocker gasket or head gasket???) alright guys, I think Ive added the picture?? Well I attached it anyway so it should be there, obviously the arrow points to where the oil seams to seap from. And this is following a thorough wash of the engine, jet washed it clean yday and refilled the oil, and it gradually leaks from there? Also, Havent checked the sump gasket, not aware where it is! Thing is I havent really got the money to be gettin a mechanic in, so if its too technical Im not guna be able to sort it lol
| | #8 | ||
| Bravo 1.8 HLX FTW | Re: Oil Leak (Rocker gasket or head gasket???) it all still looks a bit muky so cant say for sure you sure it's not just coming down from the rocker cover still also i see you still have a plastic cover over your ignition coils this should be removed as they cause coils to overheat fiat released a service news about it years ago
__________________ GOD of the the 5 Door Liberation Front ![]() Founder of the Heraldic Blue Bravo HLX Liberation Front ![]() Last edited by littlepip17; 01-04-2008 at 00:07. | ||
| The following user says "Thank You!" to littlepip17 for this useful post: | ||
stayinfly (01-04-2008) | ||
| | #9 | ||
| Re: Oil Leak (Rocker gasket or head gasket???) yeh the picture was taken before I cleaned it or even replaced the gasket as i was showing some else the problem, but where the arrow points to is the exact place where the oil seaps through now. Its a thin line which hasnt increased for 3 days, I'll try and put a pic up soon of how it looks now And what shall i do about the plastic cover, just take it off and leave it exposed? To be honest I duno where ya talkin about lol
| | #10 | |||
| 5 pots rule!! | Re: Oil Leak (Rocker gasket or head gasket???)
![]() this bit circled
__________________ Previous Car : 2002 Mk2 Punto Active Sport in Broom Yellow Everday Car : 1999 Mk1 Punto Sporting in Silver Weekend Toy : Stilo Schumacher GP Last edited by red-devil; 01-04-2008 at 02:27. | |||
| | #11 | ||
| right so in the pic, u got the air filter, the rocker gasket and the manifold of the engine beneath that.......and on the right hand side of all this (creeping in from the left hand side of the picture) Is a black object, simply just remove that?? thanks for your advice mate
| | #12 | |||||
| | #13 | |||
![]() too fast for each other lol! ;D
__________________ Previous Car : 2002 Mk2 Punto Active Sport in Broom Yellow Everday Car : 1999 Mk1 Punto Sporting in Silver Weekend Toy : Stilo Schumacher GP Last edited by red-devil; 01-04-2008 at 02:28. | |||
| The following user says "Thank You!" to red-devil for this useful post: | ||
| | #14 | ||
| Bravo 1.8 HLX FTW | Re: Oil Leak (Rocker gasket or head gasket???) ok ill be awaiting some new pics of the problem if there is definitely no oil above below and to the side of the leak then it could well be a pourus head | ||
| | #15 | ||
| Re: Oil Leak (Rocker gasket or head gasket???) There ya go lads, as you can see it appears just to seap through the areas the arrows point to......so where chall we go from here? Also why do I have to remove the plastic cover from the ignition coils? Just to reduce the overheating risk? And literally I jus remove the cover, dont need to replace it with anything else? yet again thanks for ya help lol
| Tags |
| gasket, oil leak |
| | oakld | Punto | 6 | 02-03-2008 18:35 |
| | _Sanchez_ | Cinquecento / Seicento | 3 | 26-10-2007 22:50 |
| | Parr | Punto | 6 | 20-03-2007 18:14 |
| Oil leak from head gasket | camper85 | Ducato | 0 | 31-01-2007 16:15 |
| | NickDeacon | Cinquecento / Seicento | 8 | 15-04-2006 11:41 |
