The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto > Punto > Technical
Old 10-07-2004   #1
Trader Rating: (0)
New Member and Help Please
Hi new member here.
It's actually my girlfriends car but seeing as I have to do all the work on it, this seems to be the best place to find out whats what.
I used her car to jump start mine after it had been lying for a few weeks. Got mine going but when she drove hers to the shops the injection warning light stayed on and the car is running rough as hell, sounds like its not completely firing on all cylinders and wants to stall but not quite. There was also a smell under the bonnet like burning rubber or something similar. ;)
I've checked the archives and the possibles seem to be coils, lambda or EGR.
Whats the most likely and is there any checks I can do before I start shedding out money for parts. Where are the coils and is there any checks that can be done with a multimeter or something?
Andy
andytivver is offline
Old 10-07-2004   #2
Ned
Trader Rating: (0)
You did not say what model/year it is, but the coils do fail on old and new versions,but the 99onwards also have the ecu failure this stops switching one of the coils,there is a software update recall out for these, so you will be contacted by post but if its only running on 2 cylinders you need to get it attended too
Ned is offline
Old 10-07-2004   #3
__________
dave's Avatar
Trader Rating: (9)
dave has donated! Saint Kitts and Nevis
Hi and welcome:)
coils are at other end of plug leads if no spark posible coil pack,
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
smooth binki, digging binki, waiting for headrub binki, running binki,
dave is offline
Old 10-07-2004   #4
Trader Rating: (0)
sorry, it's a '96 Punto 75 SX
Old 10-07-2004   #5
Trader Rating: (0)
must be a first for fiat!!!
the car seems to be working fine this morning. maybe i just upset it temporarily when i used it to jump start mine. :)
Old 11-07-2004   #6
Trader Rating: (0)
and bad again.
seems to be happening when leaving tesco... and all the bleeding speed hills there!!!!
Old 11-07-2004   #7
The Negotiator's Avatar
Trader Rating: (0)
The Negotiator has donated! United Kingdom
Maybe it prefers Sainsburys or Asda?! :p;)
Sorry, good luck with fixing her car :)
Uno 1.0ie Start. Standard.
The Negotiator is offline
Old 21-07-2004   #8
Trader Rating: (0)
Fixed maybe... we'll find out tomorrow.
Anyway, if anyones interested it looks like the rear ignition coil.
Very weak spark on #1 although 4 was ok (i know they are on the same coil). Also, the resistance on the primary winding was fluctuating quite a bit away from the recommended readings between when the car was working fine and when it had problems.
So, 1 coil being fitted tomorrow so hopefully that will cure the problem.
vB code is On
