| | #1 | |||
| Italians do it better :P | brakes question Hello, I just changed the front pads today as they were really low. mot is tuesday *crosses fingers*. my question is, the pads i removed were 2-3ml lower 1cm in width all across the outer edge on the friction material. i dont know if that makes sense, basically they were worn more on the outer bit. as a consequence the disk had a lip that must have worn the pad this way. it was only on the inner pad, but it was the same both sides. what would cause this?
__________________ 2000 X Seicento Sporting, Yellow 1108, 2004 54 Punto Van, White 1.3 16v MultiJet muore la pecora muore l'agnello muore la gente piena di guai... ma i ROMPI COGLIONI non muoiono mai! ![]()
| Re: brakes question corrosion, sounds like you should have replaced discs as well.
__________________ NumanR | |||
| | #3 | |||
| Italians do it better :P | Re: brakes question it was standing for a while before i brought it come to think about it... I didnt know the disks were like this with it being on the reverse side. Nobody had the disks in stock today, and what with my mot tuesday i just ground off the lip on the disks and fitted the new pads.
| brakes need to be 'primed' every journey | StoneNewt | Punto > Technical | 8 | 09-11-2006 20:44 |
| Uno Turbo Brakes | F R O S T Y | Uno > Technical | 11 | 31-05-2005 01:53 |
| Brakes question - stupidity alert | Helz | Lets Talk FIAT | 8 | 18-05-2005 22:41 |
| Rear Brakes Question | Chris0288 | Punto > Technical | 9 | 17-04-2005 20:43 |
| Advice - Brakes on my 00 Punto | esther Von Trapp | Punto > Technical | 7 | 24-08-2003 01:44 |
