The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto > Punto > Technical
Old 25-08-2007   #1
Riding 7cm of the deck
raptor's Avatar
Trader Rating: (0)
raptor has donated! United Kingdom
Rear Spring removal
have got the damper out fine, so i thought it was imple task of lowering the jack supporting the trailing arm to allow the spring to come loose.
well no such luck.
i've let the jack of the trailing arm as far as it can but the trailing arm is not dropping far enough to allow the spring to unseat at the bottom.
i've tried getting spring tensioners in and can't seem to compress the spring substanially for removal
is there something i have forgotten to remove.
there is a little plastic thing that pushes through the bottom end of the trailing arm that seems to be holding the spring in place.
the hayns manual makes no reference to this, would removal of this allow the spring to slip out?
thanks guys, i know i've posted a lot during this suspension overhaul but i do aim to get a guide written for the site for the front and rear full suspension change over!
cheers,
Josh
http://www.fiatforum.com/signaturepics/sigpic7407_1.gif
raptor is offline
Old 25-08-2007   #2
raptor's Avatar
Trader Rating: (0)
Re: Rear Spring removal
no worries, job done.
full guide to follow for removal and refit of full suspension kit for MK1 punto (although the same principle will apply to other cars in the range)
raptor is offline
vB code is On
A handbrake which works! (Guide) circolo Uno > Technical 1 01-06-2007 16:06
Rear Brake Calipers (Handbrake Cable Removal) Neojames2k X1/9 4 20-04-2005 16:41
Updated price list 21/04/2004 Body Stylist Punto > Styling 30 09-04-2005 16:02
Rear Window Removal (Window Tinting) killa_bees2k Punto > Styling 4 06-04-2005 21:11
DJ Bucho is back DJ_Bucho Cinquecento / Seicento 19 14-05-2004 17:41
