The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto > Punto > Technical
Old 04-07-2007   #1
Trader Rating: (0)
sump replacement
hi, looking for help!
my garage says that the sump to my X reg Punto needs replacing. To save money, Ive tracked down a new sump off ebay and have asked my garage to fit it. My garage say they will need 'sump gaskets' too so they can fit it, but i cant find mention of these anywhere amongst parts sellers. Can anyone clarify, will just a good sealant do???
balajit is offline
Old 04-07-2007   #2
__________
dave's Avatar
Trader Rating: (9)
dave has donated! Saint Kitts and Nevis
Re: sump replacement
use a different garage. they don't have gaskets they use a sealant
Binki
dave is offline
Old 04-07-2007   #3
Trader Rating: (0)
oh thanks. that makes sense.
is there a particular type of sealant i should get....??
balajit is offline
Old 04-07-2007   #4
__________
dave's Avatar
Trader Rating: (9)
yes RTV sealant
Binki
dave is offline
Old 04-07-2007   #5
Trader Rating: (0)
I am told the fiat sealnet is best and is only £3 anyway.
Ex punto mk2 owner 1.2 8v with 94bhp.
Now owns a seicento sporting abarth bog standard and loving it!
Lowtechguy is offline
Old 04-07-2007   #6
__________
dave's Avatar
Trader Rating: (9)
some one on psc said it was £14, RTV in a mastic gun cartridge from motor factors is only couple of quid and mastic gun is only £1 form poundland
Binki
dave is offline
Old 04-07-2007   #7
Trader Rating: (0)
Oh right, much better solution.
Although I apply the sealent to the sump then hold it up so tube or gun the application is easy anyway.
Old 04-07-2007   #8
crabbo_1's Avatar
Trader Rating: (0)
I used Loctite Sump Sealant....#98 if I remember rightly.
crabbo_1 is offline
Old 04-07-2007   #9
littlepip17's Avatar
Trader Rating: (0)
fiat glue is about £14 but it is defo the best
cut the end of the tube so that you end up with a point of glue sticking up from the sump this way you will get the best seal and make sure the surface is clean and free from oil
when you hold it up to the engine don't let it drop again or it will bugger the seal maybe get someone to put the four nuts on wile you hold it then put the rest of the bolts in
ps. you will need the dipstick out to fit the sump
littlepip17 is offline
Old 04-07-2007   #10
thefishdude's Avatar
Trader Rating: (0)
thefishdude has donated! United Kingdom
was told by fiat guy that the sealer requires 24 hours to cure properly before you can use car. just thought i would mention it lol
2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm
thefishdude is offline
Old 05-07-2007   #11
Trader Rating: (0)
rubbish leave it for an hour before punting new oil in then you can drive it the heat will help it cure
Old 05-07-2007   #12
__________
dave's Avatar
Trader Rating: (9)
i recomend 24 hours as well
Binki
dave is offline
Old 05-07-2007   #13
crabbo_1's Avatar
Trader Rating: (0)
Loctite says 24hrs.
crabbo_1 is offline
Tags: , , , ,
vB code is On
Punto Oil Sump Replacement STEPHEN P MORGAN Punto > Technical 3 30-06-2007 20:09
Brava 1.4 Sump Replacement Big J Bravo/a > Technical 0 27-05-2007 18:28
Anyone Help With Barchetta Sump zoeh Barchetta 22 21-04-2007 18:42
Sump swop? 190daj Cinquecento / Seicento 7 06-06-2006 07:39
Marea 1.6 Weekend Sump Leak George Kidd Marea > Technical 2 19-02-2005 13:49
