| bulbs alrite guys. i have recently just bought sum blue xenon bulbs for my dipped beam in my headlights. however this probably is a stupid question but im not good with technical stuff as of yet. but when u pull the clip off does the fuse bit just pull off? i didnt want to pull it just incase it broke or damaged. cheers Mikey
| Re: bulbs huh? Usually when you take a headlight bulb out you take off the wiring connector from the back of the bulb. Then pull of a rubber thing that covers the bulbholder. The bulbholder usually has a metal sorta clip thing that you un-hook to allow you to extract the bulb...then do in reverse. Knowing fiat however....that might be totally wrong ![]()
| | #3 | ||
| Re: bulbs cheers m8 will giv it a try
| Headlight bulb's R2/P45t | Alan.D | Panda (Classic) | 67 | 06-03-2007 16:28 |
| ultra xenon bulbs | ger | Punto | 1 | 02-11-2006 19:47 |
| Replacement bulbs for HID look, opinions and advice | kritip | Cinquecento / Seicento | 7 | 03-07-2006 08:19 |
| high power headlight bulbs | scottc1088 | Cinq/Sei > Technical | 16 | 20-01-2006 00:27 |
| New bulbs and few probs/questions. | Horney | Cinq/Sei > Technical | 8 | 06-12-2005 14:49 |
