The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 28-04-2005   #1
Trader Rating: (0)
Punto Sporting Steering Wheel
anyone know how to fit a different steering wheel onto a punto sporting, R REG
cheers
si23uk is offline
Old 28-04-2005   #2
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Re: Punto Sporting Steering Wheel
has it got an air bag, if not you just remove horn push, and undo nut, remove old wheel. if you are fitting an after market wheel you will need the correct boss to fit the new wheel
Binki
dave is offline
Old 29-04-2005   #3
Trader Rating: (0)
it has a airbag!! do think going somewhere professional to get it fitted would be a better idea!!!
si23uk is offline
Old 29-04-2005   #4
__________
dave's Avatar
Trader Rating: (10)
there is a rumer that the bag can go off if its not removed properly.
Binki
dave is offline
Old 30-04-2005   #5
meow
beau's Avatar
Trader Rating: (16)
beau has donated! United Kingdom
aparently in the max power haynes manual you dis connect the battery, leave the car for 20 mins so the little charge runs out and then it shoudnt go off, but apparently if you drop it or give it any sort of force it will go off.
1993 Uno Turbo / 1995 Punto 55 / 2000 Punto JTD
1998 Punto Sporting / 1993 Ford Escort 1800 16v / 1998 Fiat Bravo HLX
beau is offline
Old 30-04-2005   #6
Trader Rating: (0)
Malta
Might I suggest to be very careful with the airbag, man, it can hurt you, not just finacially but even physically.
When I had to remove me pre-tensioners for the seatbelts I took it to a professional who installed a resistor instead of the pre-tensioners.
--- Punto mk2 8v---
*Int & Ext neons**Tinting**Int Alum trim**Momo gear set**Momo pedal set*
*Body graphics**Custom Ice install**Custom A'Pex Integration CAI**Sports exhaust**Racing Seat Belts**Removed seats**Lexan Windows**Weight reduction*
Neo-The Matrix is offline
(T) steering wheel knock oliverschepisi Punto 7 06-01-2004 02:46
(T) Punto 1.6 Sporting Rabid Gerbil Bravo / Brava 0 03-01-2004 18:01
