| Debadge Question Iwas wondering, i hav a mk2 punto and as i understand you can remove the rear badge without leaving any holes but can u remove the front badge? Jus wondering cause i dont fancy holes in the front of my car
__________________ 2003 Mk2 1.2 8v Punto (Standard) Wanted Mods 1. 15" or 17" alloys 2. Drop the front 35mm and back 30mm 3. Induction kit and exhaust | |||
| | #3 | |||
| punto porn :D | Re: Debadge Question
| | #4 | ||
| Re: Debadge Question Thanks, saved me from getting impatient an jus ripping them off .
| | #5 | ||
| punto porn :D | Re: Debadge Question | ||
| | #6 | ||
| Re: Debadge Question You can use a hairdrier to heat up the rear badges to make them easier to take off (don't roast that paint tho), then just need maybe some WD to get all of the adhesive off and some t cut etc to polish and ur good to go. For the front you can just fill in the holes, prime and paint. Don't think itd cost much if you get someone to do it for you.
| | #7 | ||
| Re: Debadge Question Thanks, i will do it lateras ihave woken up to a flat tyre ![]()
| | #8 | ||
| Re: Debadge Question I pulled mine off when I got it and it did no damage. Get a bowl of hot soapy water, (out of the tap, not the kettle), and give them a good soaking, and I mean a GOOD soaking. Then use an old phone card to prise them away from the body. This works better than a hairdryer as the glue holding them on gets tackier when wet. Then get some glue or tar remover from your local motor shop, I got some cheap "Sticky Stuff Remover " from halfords for a fiver and it worked perfectly getting the residue off. Also whilst I'm here I'd like to ask about Will they replace and cover the holes left over from the bonnet badge,I reckon it would look 100% better than the blue one I have on my Red Punto.
__________________ Last edited by smokeyjoe03 : 09-07-2008 at 16:01. | |||
| | #9 | |||
| Technician | Re: Debadge Question
EDIT - from the same seller aswell Alan
__________________ ![]() Seicento Sporting 1.1, Punto 1.9 JTD, Punto 1.3 Multijet, Bravo T-Jet 150 Sport, Impreza STi PPP Links to guides - JTD Crank Sensor, Punto Juddering Wipers , JTD MAF sensor Bravo 198 Warning lights Bravo 198 Service Schedule | |||
| | #10 | ||
| Re: Debadge Question I have the new red badges on my 2B.. think it's the only one. ![]()
| | #11 | |||
You mean the New badges? Like the one on the Bravo??? Are they a similar shape/size?
__________________ | ||||
| | #13 | ||
| Re: Debadge Question Yeah i did it, altho the part of the paint where the Punto badge was has left a kind off faded "Punto" mark on it, ill get a pic tommoro cause its dark jus now but any ideas ifit can be fixed?
| | #14 | ||
| | #15 | |||
| Top Dog | Re: Debadge Question
| Debadge | R12MUS | Punto > Styling | 27 | 01-05-2008 00:02 |
| how to debadge????? | jake_6_9 | Punto | 7 | 25-11-2007 03:59 |
| Debadge my Marea | lib319 | Marea > Technical | 4 | 05-12-2005 11:42 |
| Debadge or not to debadge? | GhostWKD | Put it to the Vote... | 28 | 23-07-2004 21:03 |
| Hmm to debadge or not to debadge? | yellow_sei | Cinq/Sei > Styling | 3 | 28-04-2004 20:38 |
