FIAT Auto Specialist Team
Comment
Guide Tools
<!-- google_ad_section_start -->Punto Mk2B 1.4 16V Sporting - Cambelt / Timing belt Replacement<!-- google_ad_section_end -->
Includes replacement of tensioner and water pump.
Published by jonnyaykroyd
23-01-2013
Difficulty Level: 3
User Rated:
Difficulty Level: 1
Hi All!
A mate and I like to do a bit of "Wheeler Dealering" in our spare time and our latest project was a 2005 Mk2B Fiat Punto 1.4 16v Sporting with engine code 843A1.000.
You can also find this guide at my mate Matt's blog mattinthelakes.blogspot.co.uk where you will also find records of our other mechanical projects which to date I'm pleased to say have all been a huge success! Mike and Ed would be proud......anyhow back to the matter in hand. Cambelt 1.4 16V Sporting!
This guide is a little thin on images so I have tried to be as accurate as possible with my words. Please comment or ask questions if unsure.
Background
To get this car ready for a new owner the car needed a new radiator, cam/timing belt and water pump (replaced as a matter of course as one always should). The radiator is an easy job but when swatting up ready for the cambelt job (always best to be prepared!), it turns out it’s quite different to the older Mk2 1.2 8v which (we can say from past experience) is relatively straight forward.
Having looked across the forums on the morning of the belt change (yes, we realise we maybe should have looked prior to the day of the job) and been presented with posts to the sentiment of “You must use the correct locking tools or the engine will be destroyed” we started to think maybe this isn't going to be so straight forward after all. However, following a lengthy discussion, debating the reasons for locking tools and the associated "official" timing method prescribed by fiat, we decided that there had to be a way to do the job without special tools and proceeded.
Here is the way we did it, [B]without any of the special tools[B], but following the principles outlined in official repair procedures.
Disclaimer: The method that follows worked for us. We are not saying this is THE way to do it or that it is the best way to do it. We are just sharing this information so that it may help others. If done correctly, with a full understanding of what you are doing, then there is no reason why a DIYer/enthusiast should not be able to do a timing belt on this engine. In the absence of this information on the internet when we did the job we felt we should share our experience so that it may help others. The risk free way to do it is to pay a professional. If you disagree with our methods, don't understand our methods or don't feel confident in any way then don't do it! The locking tools are available on eBay to buy but they are expensive and this isn't likely to be cost effective to the DIYer. Ultimately if you try it and it doesn't work, well that’s just hard luck! I/we take no responsibility if you mess up your engine timing and cause expensive damage in the process. THIS IS AN INTERFERENCE ENGINE! PISTONS CAN MEET/HIT VALVES IF THE ENGINE RUNS OUT OF TIME!
Tools Required
Jack
Axle Stand
Piece of wood
A good selection of sockets/spanners/screwdrivers
Spark plug socket
A good selection of allen keys or hex bits
A 10mm allen key and a medium sized plastic wall plug
Two wooden barbecue skewers and a pen
Tippex
90-degree angled cir-clip pliers
Water pump pliers
A small mirror
Parts
Cambelt Kit (Belt and Tensioner) - We used Contitech CT1049K1 (try ebay)
Water Pump - We used KCP 1977 (again ebay)
Materials
Silicone Sealant (for water pump)
Coolant/antifreeze (red stuff)
Jubillee Clip (~40mm dia)
Method
  1. Raise the vehicle on the offside side front sill and support with an axle stand. Remove the wheel and the piece of trim covering the crank pulley. This is held on by 2 or 3 screws one of which will require the front half of the wheel arch liner to be unscrewed and pulled back to get to it. These crosshead screws can get a little seized. One of ours just wouldn't budge so we got a small, blunt drill bit and drilled the centre of the crosshead. This put heat into the screw without damaging the head too much and free'd it off.
  2. Drain the coolant by removing the bottom hose of the radiator. If this clip has never been removed it will need to be broken off - pry it open with an old screw driver. A replacement jubilee clip will be required for re-fitting later.
  3. Remove the airbox.
  4. Remove the individual coils which are held in place with 10mm bolts. Remove the bolts and pull the coils out.
  5. Remove all 4 spark plugs.
  6. Important note on timing procedure: The correct way to change the belt on the engine is to do it with the pistons at mid stroke (NOT Top Dead Centre); specifically piston 1 (nearest the belt) on it's intake stroke. As described in the following paragraphs the camshafts are to locked at this position for the timing belt replacement procedure. Only the exhaust cam shaft needs locking and in turn the inlet cam shaft will also be locked.
  7. Take a hex bit (6 or 8mm - can't remember) and remove the plug on the front of the cam cover roughly located above the right hand side of the exhaust manifold. This will reveal the exhaust camshaft through the hole. A mirror helps to see in the hole as it is below the level of the bumper.
  8. Support the engine by placing the jack under the sump. Use a piece of wood between the sump and jack to spread the load and prevent damage to the sump.
  9. Remove the offside engine mount and cam belt cover. There are 6 13mm bolts which fasten the bottom half of the mount to the cylinder head. One is deeply recessed in the centre of the mount - the best way we found to tackle this (due to the limited clearance down this side of the engine) is with a small 3/8" breaker bar or ratchet, universal joint and regular socket.
  10. Using a 13mm socket (12 point type is best) on a small breaker bar, turn the aux belt automatic tensioner clockwise to take the tension off the belt )(easier from underneath) and remove the belt.
  11. Remove the harmonic balancer pulley from the crank sprocket - 3 bolts hold it on (helps if you have a mate in the car to apply the brakes with car in 5th or 6th gear to prevent crank from turning).
  12. Raise the engine with the jack, getting it as high as possible without over-stressing the exhaust flex pipe and other hoses.
  13. As previously described, the correct way to change the belt on this engine is with the pistons at mid stroke. Place your 2 wooden skewers (of equal length!) down the spark plug holes of cylinders 1 and 2 so that they sit on the piston crowns. Use a big ratchet with 15mm socket to slowly rotate the crank. Keep rotating the crank until a SQUARE NOTCH appears in the cam case window (might help to have a second person to watch the window whilst the other rotates the crank) and the 2 skewers are roughly level.
  14. With the square notch in the hole, take a 10mm allen key and insert it though the hole and into the notch. If the engine pistons are not exactly at mid stroke then you may have to very slightly adjust the crank either backwards or forwards to get it to slot in - it's a snug fit. Check that pistons are exactly at mid stroke by marking the wooden skewers with a pen at the level of the cam cover, removing and comparing them - should be about right.
  15. The 10mm allen key is smaller than the hole in the cam case so to hold it in place take a medium sized plastic wall plug, break in half and wedge the allen key top and bottom. The cam shafts are now locked in place with your homemade/improvised locking tool!
  16. With the pistons level at mid stroke and the camshafts locked, use tipex to mark the position of the crank and cam sprockets relative to the block and cylinder head respectively. We also marked the old belt at these positions and the direction of rotation (there is a reason for this as will become clear).
  17. Undo the retaining nut on the tensioner pulley and remove it with the belt.
  18. Before you attack the water pump, take the old belt which you have just removed and count the number of teeth between the two marks on the front side (i.e. the run between the cam, over the water pump and crank on the front side of the engine). We counted 61 teeth between the marks on ours but depending on exactly where you choose to make your timing marks could mean that you get a slightly different number.
  19. Put identical marks on the new belt. The reason we did this and the reason why we recommend you do this is so that when you come to fit the new belt, you can put the belt on and just line it up with your timing marks on the engine and sprockets. Be sure to note the correct direction of rotation of the new belt before marking it up and make sure you remember which marks are which (cam / crank).
  20. At this point remove the water pump and replace with a new one. Use a small stanley knife blade and a scouring pad to clean the block mating face of the old silicone.
  21. Fit the new water pump. Ours came with a paper gasket which required a bead of silicone sealant on BOTH sides of the gasket.
  22. Install the new belt. Start by lining up your cam sprocket marks, hold in place and then run it around the water pump and down to the crank sprocket. Here you will probably notice that without the tension on the front side of the belt, your crank mark on the belt is 1 tooth short (i.e. forward) of the crank mark on the sprocket.
  23. At this point turn the crank backwards (anticlockwise) very slightly (half a tooth max) and refit the belt round the crank. This should allow you to get the belt on with everything lined up.
  24. Now the tricky bit...tension the front side of the belt slightly by repositioning the crank back to its correct location whereby your mark on the crank sprocket is now back in line with your mark on the block. The cam sprocket cannot move as it is locked in position. This will give you just enough slack on the back side of the belt to install the new tensioner.
  25. Install the tensioner and with cir-clip pliers set the tension to max tension.
  26. Check all your marks are still lined up and if all looks good, remove the allen key and wall plug wedges from the cam shaft and turn the engine over by hand 1 full revolution (2 full turns of the crankshaft).
  27. At the end of 1 full revolution the marks on the sprockets should align with their respective marks on the cam case and block. Note however that the marks on the belt will not return to their original position after 1 revolution as the belt is longer than one revolution such that it is long enough to go round the water pump and tensioner. For piece of mind you can also check that the wooden skewers are level and your 10mm allen key should slot back into the camshaft locking hole.
  28. At this point, if you are happy, set the tension to the normal setting, turn the engine over again 1 full revolution and recheck your marks and tension. Again don't expect the marks on the belt to make sense. What is important is that the sprocket marks are aligned with their respective marks on the engine.
  29. Now as haynes say, refitting is the reverse of the removal procedure.
  30. Lastly, fill up with a 50/50 mix of water/antifreeze, bleed the cooling system and fire her up. Job done.
As a final note, I'd just like to point out where we deviated from the official/fiat procedure and had to improvise. The official procedure says before fitting the new belt, take a cam sprocket holding tool (google "sealey VS173" for example) counter hold the sprocket whilst loosening the sprocket retaining bolt. This will then allow the sprocket to spin freely on the camshaft. Then providing you don't move the crank, you can fit your belt at any position. Applying full tension to the belt with the tensioner will then tension the whole length of the belt evenly as the cam sprocket is allowed to move independently of the camshafts. Finally re-tighten the cam sprocket retaining bolt at its rest position (counter-holding with the special tool), rotate by hand to check and set to normal tension. We didn't have the the VS173 and as the locking mechanism of the camshaft is NOT design to hold the force required to undo the sprocket retaining bolt we didn't attempt this method.
From past experience a cam sprocket holding tool would be a great addition to any mechanics tool kit, therefore if I had to do this again I may consider spending £15 on the tool and try the official method for the belt replacement on this engine.
Hope this helps someone out as many amateur guides and how 2s have helped me out hugely over the past few years.
Likes DigDug liked this post
Old 17-06-2014   #1
Egypt
Re: Punto Mk2B 1.4 16V Sporting - Cambelt / Timing belt Replacement
well done ,,,, you didn't mention any sort of torque wrenches in lighten the cam and crank sprockets ,,, Is this mean its useless ,,and we can go without it ?
macdiv is offline Reply With Quote Quote
Old 18-06-2014   #2
Quote Originally Posted by macdiv View Post
With our method there is no need to loosen the cam or crank sprockets. Therefore you don't need a torque wrench for these.
jonnyaykroyd is offline Reply With Quote Quote
Old 19-06-2014   #3
Egypt
OK ..But Do you need it for the rest of the job like torquing the crank pulley etc, or it doesn't mater
Old 19-06-2014   #4
Crank pulley bolts - just snug them down. If when loosening or tightening these you find the engine wanting to turn over, then put it in gear and get a helper to apply the break pedal.
There may have been a torque for the cambelt tensioner nut but if there was I don't remember what it was off the top of my head. If in doubt I usually just snug fasteners down....no need to go mad and over-tighten stuff - this is especially risky when screwing into aluminium. You don't want to strip anything. If you're worried about a fastener coming loose you can always apply a dab of thread lock.
Old 19-06-2014   #5
Trader Rating: 10
dave has donated!
Quote Originally Posted by jonnyaykroyd View Post
fool if you don't loosen it the belt wont be tensioned right, i feel sorry for who every buys the car when the belt jumps and kills the engine.
i doubt them pistons are dead level with them skews either they are not precision made and don't sit straight.
“What is right is not always popular and what is popular is not always right.”
Albert Einstein.
Old 19-06-2014   #6
Quote Originally Posted by dave View Post
I am many things and we all do "foolish" things from time to time, but I believe this particular cambelt change was not one of them!
I am a practising engineer of 8 years with a masters degree. Whilst I am not a qualified mechanic, I have quite a few years automotive mechanical experience and have changed numerous cambelts on my cars, friends cars and project cars. We have had projects where we have rebuilt engines, sold the cars and people have been happy with the cars to the point that they have recommended us to their friends and they have bought cars from us. We have never had someone phone us up saying "that car you sold me blew up".
I disagree that the prescribed method to slacken the cam sprocket is to achieve the correct tension. The belt is of a finite length therefore providing everything lines up with the marks as described in our method, the only way the tension could be wrong along the front side of the belt is if the belt was 1 or more teeth out or the tension was not set correctly on the tensioner pulley.
I believe that the official method instructs you to loosen the cam sprocket, as without doing that you cannot get the belt on the front side correctly. We worked around this by moving the crank back anticlockwise very slightly, seating the new belt EXACTLY as the old belt (we marked old and new up exactly the same), then tensioned the front of the belt by moving the crank forward/clockwise to its original position allowing us to get the belt of the tensioner.
After the cam locking tool is removed and the engine turned over, the tension is evenly distributed throughout the belt. Unless it's a tooth out, it can't possibly be wrong. We checked the tensioner setting with numerous rotations - always stayed at the correct setting.
Obviously the wooden skewers aren't precision tools!! But they successfully allowed us to determine "mid-stroke". The required level of precision came from marking EVERYTHING (belt, sprockets and engine) up with a white marker.
I would encourage anyone reading these or other instructions for this job or any job to do there research and make their own decisions in line with their experience and capabilities.
The first mechanical job I ever did (other than change a tyre) was change my vectra 1.9 diesel cambelt and intake manifold. I like to jump in the deep end, but I always do my research before hand.
Once again I would refer all readers to the disclaimer in the original post.
Likes Cal525 liked this post
Old 29-06-2014   #7
Egypt
I really got confused now .... let me ask the precise quition again ..Could i replace the belt and the tensioner pulley without loosing the cam sprocket ? and without any cam locking tool or the stick and spark plug way ?
i can lock the crank by braking the engine with any gear shift , and the cam pulley could be marked in the old belt and teeth counted from the crank mark to the cam marked ,,,, or the belt could be slacked as DAVE was saying because the old and the new belt could be different ?....
Old 29-06-2014   #8
Trader Rating: 10
dave has donated!
do it the right way the tools cost hardly any thing and can be resold, ignore this guide its ****
Likes macdiv liked this post
Albert Einstein.
Old 15-12-2014   #9
Finland
I did this job on a punto mk2 16v without special tool using the typex/paint method
Some observations from my particular experience and best memory of the task:
1. The 2008 haynes manual says you have to remove the inlet manifold! Later pictures however show it is still on the engine. I also found no compelling reason to remove the TDC sensor electric plug or oil pressure electric plug so left it in place.
2. The tensioner is most strongly wound up when the crankshaft is rotated anticlockwise and the belt length on the tensioner side is pulling on the camshaft sprocket. The tension noticeably reduces on the tensioner when the crankshaft is rotated clockwise. The alignment marks on the tensioner tend to wobble around a bit when you are hand cranking to check the lines are still lined up
3. When I undid the tensioner after making sure the new belt was correctly marked, the camshaft sprocket rotated about 2 inches clockwise. Although this seemed like a disaster I reasoned I would be fine simply by rotating the crankshaft a little once the new belt was in place.
4. The tension in the fitted and tensioned belt is so high that it is hard to see how anybody could ever get the new belt back on correctly if the camshaft does not rotate forwards like on mine or the crankshaft is not rotated anticlockwise to get the needed slack in the belt prior to rotating clockwise whereupon the belt becomes very tight on the water pump side and the paint marks all lined up perfectly without the tensioner being adjusted for spring tension but just rotated for a tight belt with with my bare hands
5. After the job was completed the tensioner could be observed to be on the previously correctly adjusted alignment marks while the engine was idling.
6. You will most likely have to hand crank the engine anticlockwise to see the belt paint line be positioned correctly on the sprockets and adjacent engine parts because you will not have marked exactly the belt as two equal half circles and the lines will travel little by little further and further out of the expected position as you hand crank the engine clockwise. Most likely rotating clockwise you will have to do a very high number of rotations before the lines will line up again
7. As others have pointed out the special tools for this job are not expensive and can be sold later. In the UK they can be bought online for 43 pounds.
http://www.motorsport-tools.com/bgs-...-16v-8725.html
Andrewedwardjudd is offline Reply With Quote Quote
Old 23-12-2014   #10
Finland
Just noticed i have a slight gasket leak from my new water pump.......I will probably redo the timing belt job
I can think of two reasons for the gasket failure.
1. I did not absolutely remove all of the old flexible gasket.
2. I have used the wrong gasket sealant. I used permatex form a gasket 2 which I now realise is recommended for oil pans and valve covers and is slow curing. The sealant that was squashed out of the joint is still uncured when broken into. Permatex recommend a Silicon RTV.
Old 27-12-2014   #11
Finland
We live and learn. I took the pump off today and it was obvious as i removed the covers the leak had become quite bad. Once the pump was off the wrong sealant I used seemed to be in the process of totally disentegrating - I was imagining there might be an obvious failure point, but it just looked like it was in the process of being washed away.
This time around i decided to remove the stud, ie the pump is held by 3 bolts and a nut on a stud, so i could properly clean the engine side of the join.
I also had a new thermostat and was not sure if i needed it, but the engine was running a bit cold and using the heater would cool the engine even while driving down the motorway, which for sure i never noticed before even when it was something like -15C and so far this winter it has not been so cold. Comparing the two side by side in a saucepan on the stove the old one did open earlier but not by so much.
Anyway i just have to do the auxillary belt, put the covers on, put the battery back, mess around with the engine guard and get a jubilee clip to replace the one time use thermostat hose clip.
Hopefully i wont be taking the engine guard off again till the next oil change - i keep saying that though.
Old 21-09-2015   #12
New Zealand
So why not just count the teeth in the belt on the other side of the tensioner (between the cam and crank), don't move the car, get the same belt, loosen the tensioner, and make sure you have exactly the same number of teeth in the same place? Wouldn't that work?
ralphnz is offline Reply With Quote Quote
Old 21-09-2015   #13
Finland
Quote Originally Posted by ralphnz View Post
When you use the typex method you will find it is impossible to fit the new belt to line up the two engine marks, two wheel marks and the two timing belt marks without firstly rotating the crankshaft anticlockwise about two teeth. This is so because when the marks were placed on the engine and original belt the water pump side of the belt was under tension.
In the typex method, once the belt is on the wheels, you tighten the belt on the water pump side by turning the crank clockwise till the camshaft rotates before you tighten the belt on the tensioner side using the tensioner.
judderbar is offline Reply With Quote Quote
Old 29-09-2015   #14
Excellent guide! Will be doing this to my panda 100hp at some point this week. I'll probably post a thread with some pics etc detailing any issues I have.
cheers
DigDug is offline Reply With Quote Quote
Comment
Guide Tools
(G) Timing belt/cambelt - 1.4 16v Sporting - how much? deano87 Grande Punto 5 27-02-2010 14:54
(G) Punto 16v 1.2 cambelt/timing belt snapped... :( Guaje7 Punto (Mk2/2b) 21 22-12-2008 20:10
(T) mk2b sporting timing belt. daryn Punto (Mk2/2b) 18 11-11-2008 17:46
(T) cambelt/timing belt replacement sukip Multipla 1 28-03-2006 17:09
