The Usual Applies to this guide
I made this guide as a way to show you how easy it is to change an alternator
All cars are slightly different, your may vary so be prepared
An Alternator is a High Amperage device Connected to the battery
There is a Risk of been Shocked - so I advise you take precautions
I am not accepting any responsibility to any damage or injury that is caused to you or the property. If you are unsure about your capabilities of doing an alternator, then you should seek professional help.
As mentioned above, this is a Guide to show you what occurs changing an alternator change. Your work is your own risk
I've made this guide for Use within the Fiat forum only
you do not have the right to replicate this work as your own
