FIAT Auto Specialist Team
Comment
Guide Tools
Resoldering Power Steering Motor Relays
try this before replacing motor/column
colinf1
22-03-2011
To check the solder joints you need,<br />
<br />
<div align="left">Allen key - 4mm <br />
Torx bit - T7 or T6 <br />
Soldering iron<br />
Soldering wire<br />
A steady hand<br />
A good light source<br />
<br />
1 - Take off fuse box cover<br />
2 - Take of bottom steering cowling<br />
3 -
Old 04-11-2016   #60
Portugal
Re: Resoldering Power Steering Motor Relays
Great guide!!
Problem solved!!
Norberto Esteves is offline Reply With Quote Quote
Old 05-02-2017   #61
sandaru has donated!
Sri Lanka
Hi, May I know what is the relay part number? Is it V23072 G1061 A308 or V23072 G1061 A108. Can I use V23072 G1061 A108 for this please?
sandaru is offline Reply With Quote Quote
Old 03-03-2017   #62
Sri Lanka
Hi I tried with alfaobd see the results it says system disabled. so how to enable this.
c1008
Motor phases
Open circuit
Failure lamp 'ON': Requested
Fault present
Test complete or not applicable
Battery voltage: 11.73 V
Recovery type: System disabled
Effort on steering wheel: -0.14 Nm
Vehicle speed: 0.00 km/h
Calculated steering position: 0.00
Motor control current: 0.00 A
Old 17-07-2017   #63
Finland
Hi, forrest159, when you made position Sensor Calibration, was your engine running?
jte is offline Reply With Quote Quote
Old 2 Weeks Ago   #64
Spot on, did this on my '00 sporting and it worked perfectly. Was looking at 80 for a new EPS motor, this ran me 8 for a set of long allen keys to take the shroud off, which I'd have bought at some point anyway
Dreamhazard is offline Reply With Quote Quote
Comment
Guide Tools
(T) power steering motor Benny 1992 Punto (Mk2/2b) 6 18-01-2011 14:24
(T) Power steering motor colinf1 Punto (Mk2/2b) 2 17-06-2010 19:03
(T) Power Steering Motor Replacement Cyat20 Punto (Mk2/2b) 4 31-01-2010 19:47
(T) Power Steering Motor and Steering Rack bridgit37jones Panda 2 27-11-2009 16:59
(G) Electric Power Steering Motor Noise? Milamber Stilo 5 19-06-2006 17:19
