Comment
Guide Tools
How to Install an Engine Push Start Button
iLeno
09-10-2010
Hey,<br />
This guide will show you how to install an engine push start button on your Punto! Installed one on my '53 Plate MK2B punto however the wiring may be different on other versions.<br />
<br />
<font color="Red"><b>NOTE</b>: You WILL need to have your keys in the ignition for the button
Old 22-10-2010   #15
dotdesign
colinf1 has donated!
Ireland
Re: How to Install an Engine Push Start Button
just as long as its a "Push to make" button its fine.
colinf1 is offline Reply With Quote Quote
Old 28-10-2010   #16
Trader Rating: 2
how to you get the cig lighter out!!!
j44aym is offline Reply With Quote Quote
Old 29-10-2010   #17
Quote Originally Posted by j44aym View Post
I knew someone would have this trouble!
There are two little dot type things on the lighter that you have to press.
I took mine to a garage, did it for free no bother
My build thread (MK2B Punto) http://www.fiatforum.com/members-mot...ml#post2594471
iLeno is offline Reply With Quote Quote
Old 01-11-2010   #18
mk2 sporting 16v
pinkbay has donated!
this looks good ive been looking at the kits but ill do this instead now does the button have to be a push springy one haha or one thats clicks so its stays on if you push it and push it again to turn off?
also does the engine turn off when u push button again?
cheers
adam
pinkbay is offline Reply With Quote Quote
Old 03-11-2010   #19
Quote Originally Posted by pinkbay View Post
cheers
adam
Hey,
I guess it has to be a 'springy' one
It doesnt hold into place like say the cig lighter button does.. its more like the button on the iPhone where its just pressed and comes back to its natural place.
Some of the other comments above indicate where you can get the button from.
And no it doesnt, its just there to ignitiate the starter motor.
Hope this helps
Thanks pinkbay thanked for this post
Old 04-11-2010   #20
mk2 sporting 16v
is it the live and earth wires that are used from the ignition barrell as i would like to do this on a different car so wires would most likely be different
thanks
adam
Old 04-11-2010   #21
thanks
adam
Honestly mate I have no idea. I got 'Dayjw' to help me with the wiring, I only know the colours of wires to use
Maybe an Auto electrician maybe able to help you out there, or someone on here.. Give 'Dayjw' a quick PM, he might be able to point you in the right direction.
And maybe search it on google? Someone may have already fitted one for your model of car
Old 05-11-2010   #22
brillient guide!
i just went to maplins and got some decent guage wire and a metal button for under 10
took about 20 minutes to get it all working and another ten mins to put the button where i wanted it
nice little mod and this guide shows just how easy it is to do!
cheers!
carrickter is offline Reply With Quote Quote
Old 06-11-2010   #23
Quote Originally Posted by carrickter View Post
brillient guide!
cheers!
Welcome mate
Old 28-01-2011   #24
Smile Re: How to Install an Engine Push Start Button
but dunto that mean if i broke in i could just press that button and away we go or do u need key in and turnd the press button tb asam doing it atm ta
rik123redbass is offline Reply With Quote Quote
Old 10-05-2011   #25
I am currently installing my push start button just now but I am not to sure on which wire is terminal 15 and terminal 50 it is either the red wire or the brown wire.
Any help would be great Thanks Kirsty x
Punto1990 is offline Reply With Quote Quote
Old 16-05-2012   #26
Evil genius in the making
ormo has donated!
Balloon Shooter Champion, Bean Hunter Champion
Sorry to drag up a year-old post, but just wanted to say thanks to iLeno This guide helped me install the push-button engine start in my Punto, and I'm loving it!
I managed to squeeze two contact pads behind the blank button on the centre switch rail (hazards, electric windows, etc.) and wire it up to send 12V from the cigarette lighter to a relay that then does the job of the button in your guide. Only took an hour or so to put it all in, and it means I can keep using my sat-nav charger
ormo is offline Reply With Quote Quote
Old 10-08-2012   #27
I purchased a richbrook "kit" online, the instructions were completely incomprehensible and included relays and all sorts, this guide shows you don't need all that rubbish and is incredibly simple to do
Puntomk284 is offline Reply With Quote Quote
Old 27-08-2012   #28
Great guide mate u covered everything. Has anyone else noticed that if you push the button without the key in the engine turns over but doesn't start. Then if you turn the key so the dash lights come on then it does start. just wondered if its normal
2002MK2 is offline Reply With Quote Quote
Old 27-08-2012   #29
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Quote Originally Posted by 2002MK2 View Post
Completely normal, the button activates the starter but without the key in to deactivate the immobiliser (and turned to engage the electrics) the engine won't fire up.
Eklipze3k is offline Reply With Quote Quote
Comment
Guide Tools
(T) Push Start Button Stealth Locky Grande Punto 6 28-09-2010 10:23
(G) Push Start Button!! Westwell11 Grande Punto 7 06-06-2007 01:02
(G) push button start punto18 Punto (Mk2/2b) 8 02-06-2007 22:21
(T) push button start Donkey Cinquecento / Seicento 9 24-11-2004 15:47
