Comment
Guide Tools
Fitting A Focus Induction Kit (8v 1.2 Punto).
Just fitted mine, now looking to help other users.
Bolted
11-08-2008
Before we start I seriously recommend any members to buy one.<br />
<br />
They are EXCELLENT value for money at just over 30 quid.<br />
<br />
The car I fitted <b>mine</b> to is an <b>04 8v 1.2 Punto (Mk2B)</b><br />
<br />
They have made quite a big difference to the sound of my car, and also
Old 08-11-2011   #375
Re: Fitting A Focus Induction Kit (8v 1.2 Punto).
just fitted my focus induction kit today, i found that you don't need copper piping, all i done was made a 1inch cut on the provided blue pipe, stretched it over the oil cooler pipe and used the small clip provided to firmly hold it in place. It works perfectly because i wasn't able to use piping so i found that this technique works. however how do you use the bracket to secure it to the battery tray holder as i cannot find any way of connecting the holder to the induction piping! :S
mbonner02 is offline Reply With Quote Quote
Old 26-11-2011   #376
mikef1994 has donated!
Hi guys, just wanted to know if this is the right kit, as it says its designed for the mk2 1.2 8 valve punto, but i was after the one that that was originally designed for the focus as most people have gone for, be good if someone could link me to the right one, cheers
Mike
http://www.ebay.co.uk/itm/99-03-Fiat...item5d2fa2a5f4
mikef1994 is offline Reply With Quote Quote
Old 26-11-2011   #377
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Quote Originally Posted by mikef1994 View Post
Mike
http://www.ebay.co.uk/itm/99-03-Fiat-Punto-MK-2-1-2L-8V-Air-Induction-Kit-/400231146996?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item5d2fa2a5f4
That's the one
Eklipze3k is offline Reply With Quote Quote
Old 11-01-2012   #378
im looking for an induction kit for my 2004 punto can someone please post a link to one?
cheers Chris
cshearer92 is offline Reply With Quote Quote
Old 08-07-2012   #379
Exclamation Re: Fitting A Focus Induction Kit (8v 1.2 Punto).
I have fitted this kit on to my car and it seemes to make it a little bit slower tham befor!! does anybody know why? i have a 55plate punto 1.2 8v active sport.
lolls8 is offline Reply With Quote Quote
Old 10-01-2013   #380
Quote Originally Posted by Bolted View Post
The car I fitted mine to is an 04 8v 1.2 Punto (Mk2B)
They have made quite a big difference to the sound of my car, and also increased it's economy (although my air filter was blocked I suspect).
Do not try buying these for any other engine other than a 1.2 8 valve (Mk2, and Mk2b both fit).
I'll write a little guide as many members struggle fitted these.
1) Before you start make sure you have every peice of eqipment that come with these kits.
This includes:
Steel tubing.
Blue elbow joint.
Blue circle joint.
Air induction cone (normally blue or red).
A length of thin hose.
1 small hose clip.
Various large hose clips.
2 mounting brackets.
The kit does not include
2 more small hose clips.
A small copper connection. (Can be bought from Homebase, B&Q, etc etc)
2) Once you've got everything you need start by unclipping the small spring which is holding the air filter box on.
Please note - remove the whole black box, do not start unscrewing the top screws. The standard air filter is the whole black box.
After that unscrew the 2 screws now holding the box on.
Then it should just lift up.
3) Join the air filter together trying to follow this image.
Attachment 49338
Please note the steel tubing should go down towards the engine, not any other way.
Than attach it all together using the large clips.
4) After the air induction kit is built up attach the blue elbow pipe to where the original air filter box was removed, making sure the black seal goes over the blue elbow pipe.
5) Secure that connection with one of the large clips, making sure its secure.
6) Next you'l need some copper piping connectors (not included).
The copper pipe bridges the gap between the blue air induction kit pipe and the whole the orginal air box left.
This should then be secure with 2 smaller clips (one on either side of the connector).
7) Next, attach the other end of the blue wire to the steel induction tubing. Then secure this with a small clip.
8) Now all you need to do is secure it (which is easier said than done as these kits are not specifically designed for a Punto).
Some people connect the brackets that came with the kit to the manifold bolts (under the heat protection metal). Other people secure it to the battery holder.
I secured it to the battery holder, so just go ahead and unscrew the battery holder bolt and slip one of the brackers through there.
Next attach the other end of the bracket to the steel unduction tubing (I used another large clip).
9) Basically this is just touch and go where you can find to attach it, but try and secure it as much as possible and also try to make sure the small blue hose does not touch any metal part of the engine.
10) You're more a less done. Just seel the hole on the back of the elbow bracket up with a small amount of sillicone. Tighten all your clips.
Then just go ahead and fire the engine up.
Hopefully
you'll notice a difference in sound, mpg economy, and power. (But probably not to a great extent).
Please post your results, and comments.
Cheers.
MY 8V HAS GOT k&n AIR KIT ON IT IS VERY GOOD KIT MY HP IS GONE UP A BIT WHICH IS GOOD THING
WILDPUNTO is offline Reply With Quote Quote
Old 13-01-2013   #381
rc822 has donated!
Smile Re: Fitting A Focus Induction Kit (8v 1.2 Punto).
Hi all ive noticed that this kit has its own little oil breather filter. Is this any good??
http://www.ebay.co.uk/itm/Fiat-Punto...item43b55d8a37
rc822 is offline Reply With Quote Quote
Old 13-01-2013   #382
No strings on me
Eklipze3k's Avatar
No, it'll fail an MOT because it's not allowed to vent to atmosphere.
Old 16-01-2013   #383
Pumper The Punto!
Tayl0r's Avatar
Tayl0r has donated!
Quote Originally Posted by Eklipze3k View Post
if you buy this kit how do you make it so it would pass an MOT
Tayl0r is offline Reply With Quote Quote
Old 03-02-2014   #384
hi can you please send me a link of the focus induction kit compatible for a fiat punto mk2b face lift 1.2 8 v as would like to buy one checked gsr 140 plus you got to wait ages and not worth on a 8v but can't find the right one thanks
john777 is offline Reply With Quote Quote
Old 15-03-2014   #385
Hey i am new to this forum but i want to start modifying my car and i gathered this induction kit is a good and cheap start I have searched far and wide for almost a week and I am unsure on which induction kit is the correct fitting so can someone please reply to this with a valid link from ebay/amazon any help is appreciated.
i have a mk2 facelift 5dr 8V
JohnAshman is offline Reply With Quote Quote
Old 23-03-2014   #386
Quote Originally Posted by JohnAshman View Post
This is the kit I bought, You still need to buy the copper tubing and extra small hose clamps.
http://www.ebay.co.uk/itm/FORD-COUGA...item5af8cd1b75
Stewarty is offline Reply With Quote Quote
Old 23-03-2014   #387
[quote=Stewarty;3440062]This is the kit I bought, You still need to buy the copper tubing and extra small hose clamps.
thanks mate this'll be the one i get then could you also link me to some clamp/clips and the copper piping so i know what measurement they are and so i know roughly what to look for ??
Old 24-03-2014   #388
Hose Clips - http://www.diy.com/nav/fix/plumbing-...skuId=11988777
And the copper piping is 15mm and about 1.5 inch long.
Old 14-05-2014   #389
Hi guys
I've fitted one of these induction kits to my fiat punto mia 1.2 8v but I can't get the blue elbow joint to sit tight on the throttle body so that it won't jump off at the slightest bump whilst I'm driving, I've followed the guide and also applied as much pressure to the jubilee clip at the join between the elbow and the throttle body, with the black seal from the original air box sitting correctly.
Can anyone give me a pointer in the right direction if they've had this problem before?
Cheers.
Mr Splat is offline Reply With Quote Quote
Comment
Guide Tools
(G) modifying focus induction kit for Mk1 punto? can it be done? willboyes Punto (Mk1) 67 20-07-2008 23:49
(T) MK2 8V Punto Focus induction kit fitting help LukePuntoMK2-8V Punto (Mk2/2b) 0 16-02-2008 21:27
(G) Focus Induction Kit For My Punto Towelie88 Punto (Mk2/2b) 6 15-08-2006 16:31
(T) Focus Induction Kit for Fiat Punto! dolman17 Punto (Mk2/2b) 18 10-12-2005 00:11
