Lamps by Post - For all your lighting needs
Comment
Guide Tools
<!-- google_ad_section_start -->bleeding cooling system, 8v & 16v petrol engines<!-- google_ad_section_end -->
Published by dave
24-10-2005
Unrated
User Rated:
Difficulty Level: 1
A Punto has two bleed screws: One on the top of the radiator and one at the back of the engine on the heater hose.
  • Undo both screws
  • Fill header tank right to the top
  • Squeeze all the hoses
  • Keep repeating this until a fair amount of coolant is coming out of both bleed screws
  • Do up the back one
  • Keep squeezing hoses so coolant keeps coming out of the radiator bleed screw until the coolant is at max
  • Do up screw
  • Replace radiator cap
  • Run engine until fan comes on
  • Let it cool for a couple of hours
  • Finally, check the level and top up to max if needed.
Thanks benny279, homeward, chrispyrice, Johnno260, grahampunto and 7 others thanked for this post
Likes chrispyrice liked this post
Old 20-09-2006   #1
Trader Rating: 16
beau has donated!
Re: how to bleed a mk1 punto cooling system
you not got no photos?
Maserati 3200 GT Coupe
beau is offline Reply With Quote Quote
Old 20-09-2006   #2
Trader Rating: 10
dave has donated!
if you need photos for this, then best let a pro do it
Likes mickyw liked this post
“What is right is not always popular and what is popular is not always right.”
Albert Einstein.
Old 21-05-2007   #3
Is this the same for a mk2 punto??
dannyg33 is offline Reply With Quote Quote
Old 21-05-2007   #4
Trader Rating: 10
dave has donated!
more or less yes but nipples be other end of rad
Albert Einstein.
Old 10-10-2007   #5
Thumbs up Re: how to bleed a mk1 punto cooling system
thanks for this pal very helpful cheers
SUCKSQUASHBANGBLOW is offline Reply With Quote Quote
Old 30-10-2007   #6
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
but it's all wrong
any wonder so many puntos are overheating
500 door handles fit bravo well chuffed
The Sultan is offline Reply With Quote Quote
Old 30-10-2007   #7
Trader Rating: 10
dave has donated!
Quote Originally Posted by littlepip17 View Post
but it's all wrong
its all totaly the best way, seems the ones that have dealer history are the ones that blow gaskets
Albert Einstein.
Old 30-10-2007   #8
Bravo 1.8 HLX FTW
The Sultan's Avatar
Quote Originally Posted by dave View Post
well i top up the reservoir open the rad screw till it comes out then shut
then open rear bleeder get someone to blow on bottle or use a pressure tester to the same affect
then shut when i come out
as the rear bleeder is higher than the bottle it will always allow air in unless you pressure it out then close it don't matter what kind of pipe squeezing you do you run the risk of having air in the block
after this obviously you should run the engine till warm allow to cool and top up the last bit
when i do it my way i never have to top it up afterwards
Old 30-10-2007   #9
Trader Rating: 10
dave has donated!
Fill header tank right to the top not the max mark
Albert Einstein.
Old 30-10-2007   #10
Bravo 1.8 HLX FTW
The Sultan's Avatar
why thats expansion space
actually i fill mine right to the plastic join between the 2halfs of the tank itgives a better idea of water level
not that i need it i have never topped mine up in 1 year just about time to change it actually
Old 30-10-2007   #11
Trader Rating: 10
dave has donated!
until the air is out, then you let it fall to max via rad bleed screw
Albert Einstein.
Old 31-10-2007   #12
Bravo 1.8 HLX FTW
The Sultan's Avatar
o right see what you mean i do actully if you let it drop you have to bleed the rad again
i bleed the rad first then open the rear bleeder and pressure till it drops to max
i suppose it don't really matter witch way round you do it
i just figure if the rads bleed first you don't push any more air into the engine
Old 31-10-2007   #13
Bravo 1.8 HLX FTW
The Sultan's Avatar
had the camera out before so took a few pictures to help people
rear bleeder
rad bleeder
bottle min max marks
max is actually the join between the 2 halves of the bottle
Thanks varesecrazy thanked for this post
Old 01-02-2008   #14
Quote Originally Posted by beau View Post
Any idea how to drain the cooling system.
Thanks Richard
gtozski@btinternet.com is offline Reply With Quote Quote
Comment
Currently Active Users Viewing This Guide: 2 (0 members and 2 guests)
Guide Tools
(T) Bleeding the cooling system Jams Doblo Doblo 5 17-12-2010 09:48
(G) Bleeding cooling system kevin47 Bravo / Brava 3 17-10-2009 09:49
(T) Bleeding the Cooling System bsafirebird Cinquecento / Seicento 12 06-11-2008 15:03
(T) bleeding cooling system? bogeyman Uno 1 20-02-2006 12:38
(T) Bleeding The Cooling System markkhan Bravo / Brava 2 22-11-2005 18:28
