FIAT Auto Specialist Team
Comment
Guide Tools
bleeding cooling system, 8v & 16v petrol engines
dave
24-10-2005
A Punto has two bleed screws: One on the top of the radiator and one at the back of the engine on the heater hose.<ul><li>Undo both screws</li>
<li>Fill header tank right to the top</li>
<li>Squeeze all the hoses</li>
<li>Keep repeating this until a fair amount of coolant is coming out of both
Old 01-02-2008   #15
Trader Rating: 10
dave has donated!
Re: how to bleed a mk1 punto cooling system
you remove the bottom hose, then fit new clip
“What is right is not always popular and what is popular is not always right.”
Albert Einstein.
Old 01-05-2008   #16
Any idea if the Mk 1 diesel is the same? I dont seem to have a bleed screw on my new radiator.
Steve A
Punto 1.7D
euro is offline Reply With Quote Quote
Old 14-05-2008   #17
i need to bleed my coolant as i may have air in it. just cant figure out how the silver fastener comes off the botom hose.
it's a 1999 v reg so im assuming its a mk2
help!!!
peehead is offline Reply With Quote Quote
Old 14-05-2008   #18
Trader Rating: 10
dave has donated!
mash it off with screw driver, after you have been to shop and bought a screw type clip to replace it
Albert Einstein.
Old 31-10-2008   #19
Hi all,
just a quick question;
Should the engine be running from the start of this process?? ie turn on engine, fill with water and then bleed??
Thanks in advance for your answer
Del
derek214 is offline Reply With Quote Quote
Old 31-10-2008   #20
Trader Rating: 10
dave has donated!
no of corse not
Albert Einstein.
Old 09-02-2010   #21
re: bleeding cooling system, 8v & 16v petrol engines
my heating not working keeps blowing cold air out all the time.any ideas thanks
rickyroo is offline Reply With Quote Quote
Old 09-02-2010   #22
Trader Rating: 10
dave has donated!
Quote Originally Posted by rickyroo View Post
if the above don't work then your head gasket be gone most probably
Albert Einstein.
Old 25-04-2010   #23
Where the hell is the rear bleed screw - is it way at the back near two rubber hoses going into the dash board?
Its the only one I can find that looks like the picture in the photo
But despite all my squeezing - nothing comes out this one - just the top one????
Also this one at the rear is no where near the radiator its behind the engine is this right??
Jake65 is offline Reply With Quote Quote
Old 25-04-2010   #24
Trader Rating: 10
dave has donated!
yes
Albert Einstein.
Old 29-10-2010   #25
I SAID GET OUT OF THE CAR
burtz's Avatar
burtz has donated!
Gunman Champion
Dave, where can you get them little clip things that need to be replaced?
Now the proud owner of a RS182
MK2b rear lights, momo strut brace and abarth centre caps for sale. PM me.
burtz is offline Reply With Quote Quote
Old 29-10-2010   #26
Trader Rating: 10
dave has donated!
you replace them with normal hose clips, get them any where
Albert Einstein.
Old 02-11-2010   #27
burtz's Avatar
burtz has donated!
Gunman Champion
Quote Originally Posted by dave View Post
Cool. Cheers fella
Old 24-11-2010   #28
will try and get some pics, but on the 1.4 16v MK2B ive been working on, the bleed screw on the heater hose is non existant.
instead it has a rubber hose that goes over the top of the inlet manifold, down the left hand side.. and goes into the radiator about half way up under the minimum and maximum marks.. presumebly to self bleed itself.
RB2009 is offline Reply With Quote Quote
Old 11-12-2010   #29
Thumbs up re: bleeding cooling system, 8v & 16v petrol engines
My Punto N reg was overheating and I realized the radiator was empty. I've filled it up and the car stopped the overheating. 1 week later it started overheating again and for my surprise the radiator was almost empty again. Then I took the car to a garage and they changed the water pump and cam belt. When I got the car back it wasn't overheating anymore but 2 weeks later when the weather got really cold I tried to use the heater and my heating wasn't working anymore. I've checked the the radiator coolant level again and it was quite empty again (under the minimum level). Then I've followed this tutorial, filled the radiator to the top (Exact 3L of coolant) , opened both bleeding screws, turned engine on, then waited it to bleed a bit and closed it again. Then I've turned on the heater and yes it started working perfectly again. I'll just keep an eye on my coolant level from now on because I don't know if it came from the garage on a low level or if it got empty since the car came from the garage (I don't know if they filled the radiator up with coolant after the change of water pump+cam belt) and I hope it stills full otherwise the car will have to go back to the garage
Thanks so much for this tutorial, is really easy to follow and works like a charm, I'm a female and I did it in about 20 min.
Liana is offline Reply With Quote Quote
Comment
Guide Tools
(T) Bleeding the cooling system Jams Doblo Doblo 5 17-12-2010 09:48
(G) Bleeding cooling system kevin47 Bravo / Brava 3 17-10-2009 09:49
(T) Bleeding the Cooling System bsafirebird Cinquecento / Seicento 12 06-11-2008 15:03
(T) bleeding cooling system? bogeyman Uno 1 20-02-2006 12:38
(T) Bleeding The Cooling System markkhan Bravo / Brava 2 22-11-2005 18:28
