Comment
Guide Tools
Brake Pad replacement, Fluid renewal and Rear Cylinder replacement.
This guide covers all three
Xen
13-06-2008
<b>Parts you will need:</b><br />
Set of Brake Pads<br />
1L Bottle of DOT4 Brake&amp;Clutch Fluid<br />
Possibly a pair of Rear Brake Cylinders<br />
Emery Cloth and Copper Grease<br />
An Assistant (ideally two assistants)<br />
<br />
Firstly loosen the bolts on the front road wheels and
Old 28-10-2011   #15
Talking Re: Brake Pad replacement, Fluid renewal and Rear Cylinder replacement.
Thanks for the guide, I've replaced brake pads on other cars before (quite sometime ago) so just needed reassurance that there wasn't anything to different.
pokitmon is offline Reply With Quote Quote
Old 10-04-2012   #16
Safety 1st!
I've not seen any mention of this in the guide, but eye protection should be used when tugging springs with pliers. A friend of one of my friends apparently lost an eye when needlenosed pliers slipped off the springs.....
Other than that, a good guide. Many thanks
ElectricFox is offline Reply With Quote Quote
Old 16-04-2012   #17
Unhappy Re: Brake Pad replacement, Fluid renewal and Rear Cylinder replacement.
Can anyone help? We're trying to replace our Mk1 Punto rear brake cylinder but can't get the nut off the back that connects the brake line. It's made of really soft metal and has gone round in our spanner What can we do?
Any help most appreciated... we've spent a week on him so far and it's been tricky at every step. The forum's been great.
Mary Faere is offline Reply With Quote Quote
Old 23-11-2013   #18
flisko's Avatar
flisko has donated!
Quote Originally Posted by Mary Faere View Post
i have removed front brake bolts that wouldnt budge with a plumbers wrench
on the other hand
my mk1 punto rear brake cylinder doesnt work and needs to be replaced
op wrote
The bung was removed before reattaching the brake pipe.
http://www.fiatforum.com/attachment....4&d=1213308603
when brake pipe is unscrewed liquid is gonna pour out?
flisko is offline Reply With Quote Quote
Old 23-11-2013   #19
flisko's Avatar
flisko has donated!
yea liquid starts pouring out, but easily stopped by that rubber cap on the cylinder itself
Comment
Guide Tools
(G) particulate fluid replacement diamond103 Ulysse 66 27-03-2013 22:57
How much? Rear Brake Pad replacement 1.2LStilo Garages 5 28-12-2007 10:47
(T) Front pad/disc replacement on MK1 Punto ceemjay Punto (Mk1) 4 25-04-2007 20:05
power steering fluid - replacement Grace Lets Talk FIAT 5 02-04-2007 14:28
(G) Brake pad sensor cable replacement fiat1100d Tempra 6 22-12-2006 14:14
