Technical regularly - wont start, stalls at lights
gavinho
O.K. driving punto mk2 1.2 8v elx 2001
intermittently (regularly) won't start, seems to start more often if i turn the key all the way, (with out turning the engine over), and leave 1-2 minutes before attempting to start it.
but i can push start it quite easily if it wont start.
stalls occasionally at lights, and have to repeat either of the above.
engine sounds lumpy, from tick over, up to 2500rpm, when in nuetral but not when driving
this seemed to start after 4th year service
has anyone got any ideas before i shell out?
use your sence check the service items air filter plugs and leads ect are they clean and in good order and more often than not the garage wont change half of what you pay for through lazzyness as when my cars have an annual in case i missed anything i quite literaly stand there and watch them while they work on my car. and as it your car its your life dont give an inch.
stephan, I think your on the same wavelength as me;)
although I simply do stuff myself, unless I don't have the equipment, in which case I'll beg/borrow/steal unless absolutly nessacery. I don't trust ANY of them.
coil packs would be my first port of call after some injection cleaner, spark plugs, ht leads
i have run the petrol down actually, thanks for the advise, i'm going to check these things when i've got some spare time in the daylight.
cheers.
now where's that haynes manual.....
