My 2001 1.2 8V punto used to heat up steadily and the heater would also get progressivly hotter.
In the past it ran at half on the temp guage, in the last few days it has been warming up erraticley, the heater has been cold when at idle even if the guage is at normal operating temperature. The heater ill start work again when the engine is reving. The temp needle will go up to the normal at half and down to quarter for about ten mins until the whole system is warmed up and then the heater seems to work as normal. I've had to top the coolent up from the min mark to the max.
There is a used thermostat on it's way to me, £22 (sound fair?), as i thought this may be the problem.
My main concern is the head gasket, when starting for the first time on a morning the idle is very rough but it soon returns to normal. There is a slight smell of petrol in the coolant but is this normal?? The oil looks ok and the level is not increasing but there is a slight white gungey deposit on filler cap.
Many thanks to anyone who can offer any advice
Ben
Ben
