My punto 55sx has just started leaking water, as you look at the engine its pouring out from under the engine where the cam belt is that where the water pump is?
Well as a guess id say if YOU can get a pump for £20 the GARAGE would say they cant get one for less than £30.
They will then charge you around £30-£50 to just open your bonnet then charge an unbelievable amount per hour for labour .
I've taken it to a garage today £170!!! He was rambling about changing the cam belt aswell because of coolant leaking on to it therefore it might snap.
i had a small water leak a few weeks ago coming from the drain plug at the bottom of the radiator so i put 3 egg whites in it and 5 mins later everything was fine and not had a problem since yeeehaaa
