Thread Tools
Old 11-09-2006   #1
Heat shield
On my wifes punto 55 (93 model) the heatshield is loose and rattling
Can this just be removed for good.
Reason I ask is same thing happened last year on my Impreza, took it to main subaru dealer who just removed them and said not really required in countries with a climate like ours
gazman is offline Reply With Quote Quote
Old 11-09-2006   #2
Falcon_II has donated!
Unhappy Re: Heat shield
I have seen people removing them but they normally protect your car against the extreem heat of the cat and if you take your car on a long or hard drive round a track the exhaust can glow red with heat. heat shiel is there to stop the car parts under it like somtime fuel lnes or brake lines from getting hot.
Also if you take a heat shield away and drive the car the exhaust at 300odd degrees will slowly heat up the cars body and paint will peel or you carpets will melt.
Falcon_II is offline Reply With Quote Quote
Old 11-09-2006   #3
Re: Heat shield
sounds extreme - melted Punto
Is this a welding job then?
Old 11-09-2006   #4
Re: Heat shield
are you on about the exhaust manifold heat shield.
| GLP - Goldie Lookin Punto | GT3 - Sporting - Cabrio | Winner Power Pro 6 pot big brake conversion, 16" OZ Crono Evo's, Spax 28 way adjustable's, Longlife custom made exhaust, Dr Evil decat, PowerOnTheRoad Seb2 ecu remap, Prima racing collins dump valve, 3 way bleed, Smoothed tailgate, Smoothed Type k rear, Abarth skirts, Smoothed MS Designs cut out front, Nomad twin pillar pod, Engine rebuild inc new pistons and more. . .
Goldie Punto is offline Reply With Quote Quote
Old 11-09-2006   #5
Re: Heat shield
Quote Originally Posted by Goldie Punto
I mean the shield which runs under the length of the car
Old 11-09-2006   #6
Re: Heat shield
Exhaust manafold stops fan wires and your radiator getting hot. still try to fix it.normally a couple of std car bolts and two washers will replace the old ones and stop the rattle.
Old 11-09-2006   #7
Re: Heat shield
its prob just came lose, been bent, or broke of the mounts, you will have to get underneath and have a look.
Old 11-09-2006   #8
Re: Heat shield
Find the bolts spray some wd on them remove them and put new washers in to hold it up.
Old 11-09-2006   #9
Re: Heat shield
Thanks chaps
very helpful
Cheers, I'll have a look tomorrow
Off for a blast in the Impreza now
Old 11-09-2006   #10
Re: Heat shield
I would check the heat shield in that one as well. LOL Thats the last car I would want to see go up on flames
Old 11-09-2006   #11
Re: Heat shield
Quote Originally Posted by Falcon_II
Sold that one
This one's fine
Old 07-10-2006   #12
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
Re: Heat shield
if fiat could leave it off with no side afects and it cos £3.50 to manufacture
£3.50 times 13 milion is a lot of dosh so i fink if its their it's their for a reasone
The Sultan is offline Reply With Quote Quote
Thread Tools
(T) Manifold heat shield LanciaMad Cinquecento / Seicento 1 06-03-2006 09:23
(T) Exhaust heat shield removal? BroomYellow Cinquecento / Seicento 12 30-06-2005 17:46
(T) Heat shield leothetiler Bravo / Brava 0 13-04-2005 17:06
(T) Heat shield Genie Punto (Mk2/2b) 8 06-07-2004 01:47
(G) please explain what heat shield is Genie Punto (Mk2/2b) 2 05-07-2004 15:34
